Need advice / lesson on welding thin steel
   / Need advice / lesson on welding thin steel #31
The best thin sheetmetal rods I have ever seen (sold) are called MG Easy Strike. You can run them in a lay down angle and they stay lit. Work very well for body work if you only have a stick welder. Mig and tig are still better. Try some ESAB .023 Easy Grind. Loaded with Silicon..No AWS class but welds flat on 24ga and grinds very easy.
   / Need advice / lesson on welding thin steel #32
i believe I have used something called easystrike. I swear, if it's the same product.. you could strike an arc and lay a bead on a piece of damp cardboard.. :) used them on a 30/70a CH baby stick welder in either 1/16 or 5/64.. don't recall which...
   / Need advice / lesson on welding thin steel #33
Hmmm, damp cardboard. I might have a need for something like that :laughing:
I've got some need for welding on thin steel so all of this is great info!
   / Need advice / lesson on welding thin steel #34
Though most advise against the 3/32 6011 rods, I like them because they start easier than the 70 series rods, and require less prep work as far as rust and paint. The amperages mentioned by most seem a little hot for my tastes, but it has been a while since I ran that small of rod. If the O/P has the rods, and takes a little time, he can get it down. Practice makes perfect, or at least tolerable.
David from jax
   / Need advice / lesson on welding thin steel #35
David from jax
I've seen a lot of different advice. I think it comes down to each person's individual technique and how they handle the weld pool. Some like the fast freeze, some like the fast flow. Thanks for your input.
   / Need advice / lesson on welding thin steel #36
David from jax
I run them at about 70-75 amps DC, low arc force, 6010 port, nice stack of dimes look.
   / Need advice / lesson on welding thin steel #37
Shops that I have worked at bulding metal door frames out of 16 ga (1/16") 200 frames a day will only use 6013 3/32 lincoln rods and they have tried everything. These frames are used in schools hospitals and most commercial buldings.
2003 Big Tex 10PI...
2007 Terex (A55973)
2007 Terex (A55973)
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
