NEED ADVICE( can't find D-rings in town)
   / NEED ADVICE( can't find D-rings in town) #11
Re: NEED ADVICE( can\'t find D-rings in town)
I have close to the same trailer, side rails look the same. I trailer my BX23 with the bh and use straps hooked to the side rails. Never had a problem with it.
I do have brakes on both axles, hope yours does.
   / NEED ADVICE( can't find D-rings in town) #12
I'm not so sure the small channel won't work on a light duty utility trailer if additional side braces are also added. (flat stock going from the 90 degree part of the channel to the trailer at about a 45 degree angle) The sides of the light duty utility trailers are only 1/4" angle anyway. That is why they have to have the additional support of the upper railing for support from flex. I'd say that with additional flat stock as I mentioned above, giving the pocket 4 places to attach to the side angle of the trailer, the attachment point will be as strong as the trailer will handle.
   / NEED ADVICE( can't find D-rings in town) #13
   / NEED ADVICE( can't find D-rings in town) #14
I like the grab hook idea!!
I make D rings outta 3/8 round rod.Make your 90 deg. bends with a half inch pipe and the D part with two bolts clamped upright in a vise.Or just bang it around with a BFH....
   / NEED ADVICE( can't find D-rings in town) #15
etrailer.com has nice weld on d rings with 11000# breaking stength if I recall accurately....
STORAGE FEES (A57880)
2007 Ford F-750 (A55973)
2007 Ford F-750...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
