Need a wider front tire
   / Need a wider front tire #1
IGT_engineering
Massey Ferguson 261
The tire and intertube on the 4x2 Massey 261 blew out this week. I work on sand predominently on sand. Dry, loose sand. Any way the stock tires tend to cut in and sink whenever I use the loader.
The stock tire is a 7.5x16. I'd like to put a much wider front tire.
What is the widest tire I can put on this rim?
I'm open to changing the rims to a wider one as well. The Massey uses a six bold pattern but I don't know what the pilot hole is.
Looking for any suggestions. lessons learned etc.
   / Need a wider front tire #2
We did exactly that to a 2020 John Deere tractor that had a loader.
In our case, we "borrowed" two 11.00 X 15 tires and wheels off of a silage wagon,, they fit perfectly.
The 11 inch wide tires were a shock, the tractor went from two handed muscle steering, to almost one finger steering.
The tires we used were the multi-rib implement tires.
The tires stayed on the tractor, we bought two new tires and wheels for the silage wagon.
Thanks for the reply. I figured someone had done this. Glad to see my thinking was not flawed.
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
PALLET OF MISC PUMPS (A54757)
PALLET OF MISC...
