Need a wider front tire
   / Need a wider front tire #1
IGT_engineering
Massey Ferguson 261
The tire and intertube on the 4x2 Massey 261 blew out this week. I work on sand predominently on sand. Dry, loose sand. Any way the stock tires tend to cut in and sink whenever I use the loader.
The stock tire is a 7.5x16. I'd like to put a much wider front tire.
What is the widest tire I can put on this rim?
I'm open to changing the rims to a wider one as well. The Massey uses a six bold pattern but I don't know what the pilot hole is.
Looking for any suggestions. lessons learned etc.
   / Need a wider front tire #2
We did exactly that to a 2020 John Deere tractor that had a loader.
In our case, we "borrowed" two 11.00 X 15 tires and wheels off of a silage wagon,, they fit perfectly.
The 11 inch wide tires were a shock, the tractor went from two handed muscle steering, to almost one finger steering.
The tires we used were the multi-rib implement tires.
The tires stayed on the tractor, we bought two new tires and wheels for the silage wagon.
Thanks for the reply. I figured someone had done this. Glad to see my thinking was not flawed.
Kenworth T800 Day Cab Truck Tractor (A49461)
Kenworth T800 Day...
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
71065 (A49346)
71065 (A49346)
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
