Need a wheel for PT-180 Brush Cutter
   / Need a wheel for PT-180 Brush Cutter #1
dturnmire
N. Georgia
Pt-180
One of the little plastic wheels on the back of a 48" brush cutter for the PT-180 broke in half and I have had no luck in finding one with a big enough hole for the bolt that goes through it. Power Trac has one for $24.99 but will not ship without at least a $50 order. I have tried all the local hardware stores and even a tractor place and though they may have a wheel about the right size, the holes in them are too small.
Does anyone know if I could use a smaller bolt or maybe a website that carries that particular wheel? Thanks.
   / Need a wheel for PT-180 Brush Cutter #2
What are the dimensions of the wheel and the hole size?
Dale
   / Need a wheel for PT-180 Brush Cutter #3
If it broke once, do you think it could happen again? Maybe order two and they'll ship them.
   / Need a wheel for PT-180 Brush Cutter #4
Find a store that sells wheels and casters for industrial hand trucks in your area. They should be able to match it pretty quick.
   / Need a wheel for PT-180 Brush Cutter #5
DTurnmire,
Hi, I know the feeling of being shunned, but regardless, Try any of these combinations.
First your wheel should be held by a 1/2 inch bolt,
If one of the wheels available has enouigh "meat" in the center, (you can judge or rely on your contact), drill the hole out to 1/2 inch.
If the hole on the available wheel is 3/8 ths 0r 7/16ths without the meat use a
bolt of that size until something more correct is available.
All the best, we can't stop work for small problems.
Bill
   / Need a wheel for PT-180 Brush Cutter #7
DHS said:
I don't know the size of your brush cutter wheels but I am considering caster wheels as a replacement for my 48" finish mower rear wheels. I believe mine are hard plastic 8x2 with 1/2 center hole.
Some options listed here. Caster Wheels - Phenolic - Rubber - Steel - Polyurethane - V Groove - Caster City
Dale
I've been using heavy duty phenolic caster wheels on my 1845 roughcut mower for several years now. They've been great - I haven't had a flat since :)
Sedgewood
   / Need a wheel for PT-180 Brush Cutter #8
Sedgewood,
Thanks for the info. I'll give them a try.
Dale
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
DRAGON 500 BBL FRAC TANK (A58216)
DRAGON 500 BBL...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
