Buying Advice Need a tractor to move my docks!
   / Need a tractor to move my docks! #1
legrandice
Western MA
Max 26 HST
Here are my requirements:
Need to lift 1000lb dock sections off a trailer and move them around.
To move the tractor around I have a smaller trailer:
Weight capacity of 3000lbs so I would like to be around 2500 or so for the tractor and loader
5' by 10' rough dimensions
I am currently looking at a Mahindra 26XL hst lift capacity of 1402 with the loader
Are there any other options that would have equal lift capacity at the pins?
Thanks in advance for any feedback.
   / Need a tractor to move my docks! #2
What are the dimensions of the "docks" Remember the lift at the "pins" is reduced by the moment arm of the load.... And the attachment weight.
   / Need a tractor to move my docks! #3
:welcome: to TractorByNet! :thumbsup:
What is the length and width of the dock sections?
1402 at the pins decreases drastically as the load gets further out.
You also have to include the weight of the bucket or forks.
Is this a one time job?
   / Need a tractor to move my docks! #4
are you moving them in/out of the water?
can you simply back the trailer down into the water, and let the docks float?
how far you need to reach out to pick them up, how high you need to lift them up. is part of the equation...
more info you give the better answers you will get.
   / Need a tractor to move my docks! #5
The loader lift capacity for that tractor is very impressive and I can see why it is appealing to you. As others said, the further out front the load center is, the lower the weight you can lift, so if the dock sections are large/wide, you may want a forklift instead where the load is usually much closer to the machine and it's weight.
You will probably be overweight for your trailer. The weight listed for the 26XL that I could find is 1,819 lbs. That is pretty light, and I'm sure is just the tractor weight not including the loader. I'm not an expert here so take it for what it's worth, but my L3800 is listed at 2,668 lbs. That is without the loader, which I believe is about another 800 lbs, so I'm already at 3,400 lbs for the tractor and loader. Then you need to consider whether you want filled rear tires for all that loader work and additional ballast for all that loader work. The only way I can comfortably get the maximum work out of my loader is by having rear wheels filled (~400 lbs) and having my box blade attached (550 lbs). That puts my total tractor working weight about 4,300 or 4,400 lbs. I have a 16' trailer and my tractor with loader and box blade takes about the whole platform and to center with proper tongue weight, the loader actually rests on the tongue forward of the platform a couple feet. I can hardly tow it with the bush hog on because it's further out and off the back and I would be looking at 20' trailer if I had it to do again. The trailer is rated at 7,500 lbs and weighs about 1,500 lbs by itself, putting my total trailer load at nearly 6,000 lbs of the 7,500 it's rated for.
Just wanted to give you an idea of things to consider as you choose the right tool for what you're doing and then consider safely trailering what you end up choosing.
I should have provided more information in the original request.
The dock sections are 20' by 4'. They are not 1000lbs, but are pretty heavy. I don't have an exact figure.
My current tractor is an ingersoll 6018 with home made forks inside the bucket. I am able to lift the sections with this tractor, but can't move them. My current practice is to lift them and drive the trailer underneath. This way I don't need to move the tractor. I borrow a 20' by 8' deck over snowmobile trailer that I load 2 dock sections on at one time. I then back that down the ramp and into the water. I want a tractor that can lift the sections up and move them around.
I need to have at least 80" of lift height
With the forks on I need to reach 24", but that should be as close to the pins as possible.
lift capacity highest as possible
total tractor weight around 2500lbs
We put in and remove the docks each year so they are not damaged by the ice.
I will try to find some pictures when I am back on my computer.
   / Need a tractor to move my docks! #7
Unless those docks are quite a bit less than 1,000 pounds, I don't think you're gonna find a 2500 pound tractor/loader that will do the job.
Your limitation is the trailer, which seems to be the tail wagging the dog in my opinion. My advice is to buy a tractor/loader that will do the job without being at the extreme edge of its capacity, and then buy a trailer with sufficient size and capacity to handle the tractor.
   / Need a tractor to move my docks! #8
ya down to slim pickings. trying to get just enough tractor to do this or that. and then compounded with the trailer.
i would say get tractor that meets your needs, and then sell off current trailer for a trailer that meets new tractor needs as far as weight. but then the question is due you have enough truck to pull both larger trailer and tractor on the road?
you say moving the docks, i am going to assume on uneven ground (dirt / rock / gravel) were you will hit ruts, or tires will sink. that alone going to push for a bigger tractor so you do not roll / tip the tractor over. bigger tractor = more overall weight, more lifting power, mower counter balance weight, hopefully wider tractor, to help stabilize the tractor when moving.
bigger issues come up when floating dock gets a leak or like in one of the pontoons, and needing to lift the extra weight of water in the pontoons if need be.
at moment backing up trailer underneath the docks (when docks held up by tractor), might be the best way of doing things. once you start trying to drive with a 20' x 4' dock. or anything that big, it is going to want to "swing" and rotate on you. and the need for a second person holding onto some rope to control the dock as you move with tractor. that extra swinging / rotating / and even some bouncing is going to put some stress on the dock frame work, causing nails / screws to want to come loose, resulting in possible damage to the dock over time. even metal frame work is going to take some stress and possibly warp / twist on you.
   / Need a tractor to move my docks! #9
Just because the loader says it can lift 1400#, doesnt mean it can if the tractor isnt up to the task. And at 2600#, it ISNT. You need substantial weight hanging off the 3PH and fluid in the tires. Which will push you over the 3000# mark.
To my knowledge, I dont know of any tractor with a trim weight of 3000# that will lift 1000# to max height. The weights just arent in the right place to do it safely and move around.
That max you are looking at, (assuming you meant 28xl) is gonna be 2600# with the loader. And to lift 1000lbs to near max height safely, I would want no less than loaded tires and 600-700 lbs hanging off the 3PH. Thats gonna put you in the 360-3800# range.
My tractor with loader weigh in the 3600# range. And I wouldnt even attempt loading that without loaded tires and my 700# blade. Puts me over 4500#
So depending on how far off your guess of the dock weights are, I am afraid that the machine you want just doesnt exist. But its hard to size a machine without knowing exactaly how much you want to lift either. A few hundred pounds makes a huge difference.
   / Need a tractor to move my docks! #10
I would also question towing a Max28w/loader on a 3k trailer as well. Being 3k, I am assuming a single axle landscape trailer with a mesh gate. Not what I would choose. You are looking at spending $10-$15k on a tractor, dont be foolish on the trailer.
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Land Honor Quick Attach 72" Skid Steer Rock Bucket (A50515)
Land Honor Quick...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
