need a new well drilled-need info.
   / need a new well drilled-need info. #1
BWS
seattle area
kubota l3830 hst/723 fel
any info on this??do we need a holding tank??what about pumps i know 240volt is the way to go but what brand?
   / need a new well drilled-need info. #2
You might scan the posts under the "Water" forum of Countrybynet. Brands? I couldn't tell you what brand I have of tank or pump. I would talk to neighbors and then get a couple of drillers out to quote. You'll learn a lot this way.
I have a pressure tank with outlet split. One branch goes to a large tank I acquired from my old well. This branch is dedicated to outside watering. The second branch goes to my water softener after which I have installed a small pressure tank to help maintain pressure in my house. I have check valves installed to keep one branch from contaminating the other.
   / need a new well drilled-need info. #3
BWS --
My drilled well goes down about 115'. I have a submersible Myers pump with 5 year warranty. It was installed in late 1980s....haven't had one problem with it. Water is pumped into a 30 gal. retaining tank with pressure valve set I believe at around 25-30 pounds. You must have a retaining tank. Otherwise every time you turn the water on in the sink or elsewhere, you'll be triggering that pump and it won't be long before the pump burns out. If you haven't done this type of work before, I'd suggest contracting with a good plumber who has. It's a bit more complicated than simply soldering a pipe fitting or two that most homeowners can get the hang of.
...Bob
the well driller qouted us 5600.00 for a 75-100ft well/pump instl.i thought there must be more to it than he has told me.we will need a holding tank.this would be the plumbers job not the well driller or do the well drllers do all the plumbing too??bws
   / need a new well drilled-need info. #5
I guess it depends on your area, that goes for price too. I had a 300 foot well put in 3 years ago. Price was around $4000. Soil is pretty easy drilling here. All quotes included hooking up electricity (which I supplied from box) and pressure tank, and plumbing up to my pipe which was there waiting for them. I did have another quote for around $5000.
   / need a new well drilled-need info. #6
I had a 450' well done a couple years ago. Price with the holding tank installed, 5 hp pump, and one hydrant was $9500. Depending on the driller they will do the whole deal or let you do the holding tank etc. with someone else. You also have to run water lines to and from your house.
hydrant??thats good info,wonder what that option costs??
   / need a new well drilled-need info. #8
It was a $100 to put in the hydrant and cost of the hydrant and $2/ft. to run the water line.
   / need a new well drilled-need info. #9
Whoa, mine ran 320 feet with the pump set at 300. Mostly rock, only took 25' of casing. Total price was just a shade over $2500. The driller don't do pumps.
   / need a new well drilled-need info. #10
I think it all depends on the driller. The welldrillers I have dealt all pretty much do it all from the well to hooking up the main water line. They put in the pumps, pressure tanks, run the lines, etc. Pretty much turn-key.
434669 (A48836)
434669 (A48836)
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
