need a new cylinder for my log splitter and need some advice
   / need a new cylinder for my log splitter and need some advice
As with everything, going through this process is a learning experience. My original cylinder which had a 4 inch barrel and a 2 inch rod had a welded tube and and what they call a pinhole or pin eye in the rod. Prince did not make this cylinder anymore in fact they felt it was probably a custom cylinder. So on the advice of another member I called Bailey's, they actually had the exact cylinder available under their chief cylinder line. Apparently they build these in United States and provide a three-year warranty. So I ordered one up this week and it should be a plug in place. And it was $100 less then the cylinder I was going to get at surplus center and that one was going to make me have to do some modifications to the ram.
   / need a new cylinder for my log splitter and need some advice #12
You made sure the fittings were the same also? Could be either ORB or NPT fittings. IF not, you may have to buy a few adapters.
I have never had any issues with any baileys products. I think you will be happy.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
1837 (A51248)
1837 (A51248)
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55314)
2019 Krause...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
