Need a measurement
   / Need a measurement #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
Hi all.
I'm looking to weld together a 3 point receiver hitch contraption this weekend. However, I need an approximate measurement for the vertical distance from the lower 3 point arms up to the top link. The only 3ph implement I have right now is my finish mower, and with the floating attachment points, I can't take an accurate measurement. If someone could measure their blade, rake, etc, I would much appreciate it!
Todd
   / Need a measurement #2
I don't have an address for you.. but do a search for asae standards for the cat 1 hitch.. it will be listed in a diagram.. all the geometry and measurements.. lacking that.. measure one of your other implements if you have any.
Soundguy
   / Need a measurement #3
Here is a nice page from SpeeCo, but it doesn't list the vertical distance.
3 point dimensions
   / Need a measurement #5
If you haven't already made it (this is Monday as I type this), I've made a couple for friends based on the averages of some of my implements and they've worked fine. The numbers I used were 14 5/8" for the height and 27 1/8" for the width. Actually, I just go on the outside of the soap line I mark at 14 1/2" and 27" but that seems to be close enough. I don't know how this matches the the actual specs, but it works well on every tractor I've tried it on (even with quick attach).
Thanks for the help guys!
I didn't get started on it this weekend as some other things came up. Now I can hit the ground running!
3ft 5-Point Metal Star (A55853)
3ft 5-Point Metal...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
