Need a jackshaft for batwing
   / Need a jackshaft for batwing #1
AllDodge
Platinum Member
S, Central, KY
Terramite T5C, Kubota M9540HDC24, F3990, RTV1100, Cat 416C, D3B, 955L
Woods 9180RD-2
Bought the woods carrier bearing and front section of the plastic guard. The bearing was froze solid and hasn't turned in some time. Pressed it out after removing the snap ring and installed, pressed in new.
The jackshaft has been wearing on the bearing a long time and needs to be replaced, has worn into the shaft maybe 1/4 inch all around
The stub end is 1 3/8 x 26.4 long. The whole unit is about 30 inch maybe an inch or so longer. Has Walterscheild 6 spline. Female quick Coupling and U joint on one side and male end quick couple on the other.
Woods wants $540 just for the stub end PN 44678
How do ya find after market?
   / Need a jackshaft for batwing #2
Back in 08, we had similar problem. U-joint went out on our 20' bush hog. Was able to buy complete drive shaft with 2 u-joints for less than half what my dealer wanted for the u-joint.
May have changed since then, but search for The Power connection, or GenPower brushless generators or tpcgenerators.com. They were a supplier of generators for chicken farms, ETC. in VA.
   / Need a jackshaft for batwing #3
Surplus Center may have something like that (look under power transmission)
Aaron Z
Thanks, will keep looking
   / Need a jackshaft for batwing #5
I second the entire assembly. Sadly it's a nightmare finding individual parts. I had two wing shafts rebuilt at a landpride dealer, not again.
This stuff is expensive regardless.
To close this one out,
Took the shaft and bearing to Froedge in Tompkinsville the other day. The bearing I had in it was 1.5 ID and they said it should be 1 3/8. Said I'm good with that, and left it asking they fix it. Got it back the next day
$95 for labor (weld area up then cut in down to size)
$22 for sealed bearing
All good and great work
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2007 MACK CL DAY CAB (A57880)
2007 MACK CL DAY...
2018 PETERBILT 567 FLATBED DUMP (A57880)
2018 PETERBILT 567...
John Deere 5105M (A53317)
John Deere 5105M...
