Need a Finishing Mower and HELP!!
   / Need a Finishing Mower and HELP!! #1
Dirtandgrass
Memphis, Tennessee
Kubota M7040 4WD HST
Hey folks,
I need some help yet again. I need to try and get myself a finishing mower. Problem is, I don't know what size I can get. I have plenty of tractor, and am afraid I might have too much.
When I started out cleaning up this 10 acres, it was pretty rough, so I was using my Kubota M7040 and a pretty beefy Rhino 7 foot rotary cutter (TW84 I think it is). Anyway, this setup has worked tremendously as I got it cleaned up and nice looking. I have been mowing and keeping it up to the point that I need to start to groom it some. The Rhino cuts great, but I need to cut it lower than the Rhino will allow me.
So, I know I have the HP to run a fairly good size finishing mower, but what things do I need to look out for? I guess what concerns me is having too much tractor for the mower and actually doing damage to the mower...ie gearbox, belts, etc. because the tractor has too much HP. Is that a possibility? I mean I know the M7040 is only a mid size type tractor, but I see my neighbors running 6 and 7 foot finishing mowers on much much smaller tractors...thats why I was concerned about damaging the mower.
I would like to get something in the 6-8 foot range. Is that possible on a Kubota M7040? Thanks much.
Regards,
G.
Grass Catcher
   / Need a Finishing Mower and HELP!! #2
At 540 rpm that is required to run the pto finish mower, the mower itself doesn't care how many hp are turning it. However, if you hit an object, you have the power to destroy a mower. You can buy finish mowers up to 7' that I am aware of and probably bigger. I run a 6' with a 25hp tractor and it does fine, it will bog down if the grass is let grow too tall (which I don't do) and I have the rear discharge (which I prefer), it doesn't clump up the grass like a side discharge does and I can mow close on either side of the deck. Landpride and Woods are both very good mowers, I have a KingKutter and I really like it, much cheaper to purchase new but not nearly as heavy duty as the higher end mowers. But yes, you can use one on your tractor and not tear it up unless you hit objects with it. Hope this helps.
   / Need a Finishing Mower and HELP!! #4
I would consider the First Choice GM35-84 a very good value for the money. I used it behind 40 PTO hp, and the tractor doesn't even know it's there.
Note on First Choice Equipment that it's 73% heavier than the six footer. That's a feature you'll appreciate when the mowing surface gets a little bumpy. I've used lighter finish mowers that would bounch uncontrollably unless ground speed was reduced through rough patches. But this one stays on the ground - at speed - over the very same ground.
//greg//
   / Need a Finishing Mower and HELP!! #5
I suspect finish mowers of the bat wing variety come as wide as your budget will allow. With 10 acres a 72" will be as small as you probably would care to put up with but the wider they get the more scalping you will get also. Even with a center wheel. I have always owned Bush Hog finish and rotary mowers, but Woods and other top tier brands offer some really nice 7' models. With that much acreage I would really try and stick with a good quality and heavy model.
   / Need a Finishing Mower and HELP!! #6
Egon said:
The slip clutch should help some.:D
On a finish mower? Waste of money. The belt(s) is/are your "slip clutch". They'll slip/smoke/break long before there's any danger of transmission/PTO damage
//greg//
   / Need a Finishing Mower and HELP!! #8
I pull a 5' mower with a separate 5' trail mower attached to the back, for a total cut of just under 9'. If you're not familiar with trail mowers:
Swisher Finishing Trailmower — 60in. Cutting Width, 13 HP, Model# T1360H | Trail Mowers | Northern Tool + Equipment
I already had the trail mower when I got the tractor. Getting a bat wing that big would probably cost a lot more money. Only drawback is the trail mower has it's own gas engine, so it's one more thing to take care of. But you can also pull it behind an ATV or garden tractor if that's any benefit.
   / Need a Finishing Mower and HELP!! #9
Caroni sells a 93" from Agrisupply for $1800. That will cut your seat time down for sure.
I am in the same boat as you.
Looking forward to the responses....
   / Need a Finishing Mower and HELP!! #10
I have a 7ft landpride finish mower with a slip clutch. I absolutley love it, except for the flat tires, but I'm changing them to solid tires, so that should take care of that problem.
I find that I can mow faster and easier with my finish mower. I only have 35hp, which gets the job done, but more hp would sure be nicer. I don't think you can have too much hp, but if the grass gets too tall, or is really thick, it will come in handy. I bog down in certain areas where my bermuda and bahia gets extra thick. I can usualy see those areas before I get to them and I just slow down and take it slow. Otherwise, it's awesome.
Eddie
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
20314 (A51694)
20314 (A51694)
Adams 8 Ton Weigh Hopper (A53472)
Adams 8 Ton Weigh...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
