Need a dual spool valve for a belarus 250AS
   / Need a dual spool valve for a belarus 250AS #1
curtis250AS
glencoe alabama
Belarus 250AS and John Deere 410E
I have a 250AS I need a dual spool valve for, any information about where to find a new or rebuilt dual spool valve would be greatly appreciated.
   / Need a dual spool valve for a belarus 250AS #2
This is your hyd data.
Hydraulics:
Type: open
Capacity: 2 gal [7.6 L]
Pressure: 2060 psi [142.0 bar]
Valves: 1
Total flow: 4.2 gpm [15.9 lpm]
There are lots of two spool valves available.
I haven't seen very any with a low flow rate.
You might get away with a 8 or 10 GPM.
Surplus Center
Would any of the valves from surplus center hook up to the banjo fittings amd mounting bolts on a 250as? I would want the best one possible.
UNUSED RAYTREE QUICK ATTACH AUGER SET (A50460)
UNUSED RAYTREE...
2012 WACKER NEUSON G50 MOBILE GENERATOR SET (A50458)
2012 WACKER NEUSON...
2334 (A50460)
2334 (A50460)
2008 Ford F-150 Pickup Truck, VIN # 1FTPW14V48FA52975 (A48836)
2008 Ford F-150...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A48836)
2007 International...
2022 Kubota MX5400 Tractor (A50490)
2022 Kubota MX5400...
