Need a Disc Harrow for M7060
   / Need a Disc Harrow for M7060 #1
cedarstump
SC
Kubota M7060
I have a 5' 3Pt hitch harrow and would like to upgrade to a pull type harrow. Any recommendations of what size Harrow the tractor can comfortably pull
   / Need a Disc Harrow for M7060 #2
Are you more interested in pull width/coverage or depth of penetration?
Monroe Tufline is a premium brand in serious ag Disc Harrows and one of the few producers of pull discs.
LINK: TW6 Series Tandem Wheel Disc Harrows | Tufline
Time to enter your new Kubota into your T-B-N PROFILE to avoid confusion. Good to add your location at the same time.
Got my info updated. looking for better depth of penetration than i can get with the 3pt version
   / Need a Disc Harrow for M7060 #4
Look at Tufline's two ranges of pull discs. If you estimate price at $3.00 per pound of implement total weight you will be about right.
For penetration research the largest diameter pans in a pull disc with an operating width just a little wider than the outside-to-outside width of your rear tires. Penetration potential will be about 40% of pan diameter, depending on soil, soil moisture and angle at which pans are set.
(24" pans = 9-1/2" potential penetration.)
A pull-disc will level small hills better than a mounted disc but I am somewhat doubtful a pull-disc will penetrate deeper than a mounted disc when both are as wide as your rear tires.
If penetration is your primary goal consider field cultivators and chisel plows. Field Cultivator will penetrate 10" in tough soil, Chisel Plow 12" - 14".
There should be a least two Tufline dealers in S.C.
I have a Tufline Disc. Quality is super-good.
   / Need a Disc Harrow for M7060 #5
We pull a 10' with our M8540HDC and it gets good penetration, no name on it and not a high dollar piece of equipment.
MASTERBUILT MEAT SMOKER (A58374)
MASTERBUILT MEAT...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
1408 (A57192)
1408 (A57192)
Portable Restroom (A54865)
Portable Restroom...
