Need a Deere drawbar
/ Need a Deere drawbar #1
Green4310TLB
PA
Deere 4310
I don't notice my tractor does not have a drawbar until I took off the back hoe... Anyway, New is $180. Anyone have one to sell ? Know of any good places to look for one? I think I could make a Ford one work. Thanks.
/ Need a Deere drawbar #2
Just a thought but if you could get some measurements by looking at the drawbar receiver on your tractor (probably don't have to be real exact) and you could check a couple machine shops, if you have some close by. They may have a piece of scrap steel laying around just about the right size and could cut it/drill it as needed. I don't think that drawbars are made from any sort of special steel, like a hardened steel, etc.
edit: Going by memory I think the drawbar on the JD750 I had was about 2 1/2" wide x 1 1/2" thick, and maybe about 18" in length. Not sure what it is on the 790 I have now (haven't measured it) but it should be pretty close to that, or maybe even the same.
/ Need a Deere drawbar #3
I used the standard Tractor Supply one on my Deere 855. I just had to drill a couple of holes but other than that, it was pretty much identical to stock.
TSC price was $40
Greg
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
Case 580L Backhoe Loader (A64047)
Case 580L Backhoe...
2R ROTARY HOE (A63291)
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
Arrow Quip 7500LMR Cattle Chute w/ Head Holder (A64047)
Arrow Quip 7500LMR...
