need 4110 help please!
   / need 4110 help please! #11
Mike, can't bodie solve the problem,it is a brand new tractor?
yeah, Bodie could figure it out....but i remember seeing that thread on this problem here before. i knew it was an easy fix, so i wasn't going to trailer it down when i could do it myself. i talked with Galen on the phone and got the directions that way. the problem is fixed! thanks for your help!
   / need 4110 help please! #13
Look under your rt side foot rest and you will see a square block and a wire & screw attached to it. Take the screw out and clean the wire and the block to make a good ground connection. If this doesn't solve your problem on the rear edge of the block you will see the solonoid which has a wire going to it. Look on the front of the block directly in front of the solonoid there is a hex head plug. Take out the plug being careful not to lose the spring inside and stick a screw driver in the hole to push the solonoid back. Spray a little light lubricant in the hole and put the spring & plug back. I believe this should solve your PTO problem.
This is something I found in a short search.
David from jax
2001 Ford Ranger XL (A50323)
2001 Ford Ranger...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
Toro Zero Turn (A50324)
Toro Zero Turn...
International 574 2wd Tractor (A52128)
International 574...
