need 2t90 injection pump
   / need 2t90 injection pump #1
j911brick
yanmar 2210
does anybody have an injection pump or parts for 2t90 engine at a reasonable price?
has a broken internal part and i need one that hasn't been taken apart for reference.
   / need 2t90 injection pump #4
I don't have a pump but can prob. help u w/ anything u need to know..
Click on my screen name for contact info.
thanks fir the offer. I'm sure ill be hitting you up before this is over. how should i remove the injectors?
   / need 2t90 injection pump #6
If they don't come out w/ a simple twisting motion.. you'll hafta rent the tool from Hoye..
They are the ones where the line{male threads} screws into the side of the injector body{female threads}.??
Turn them to the RIGHT, Clockwise.. otherwise u stand a chance of unscrewing the top of the body, leaving the nozzle nut in the head.
I JUST threw out the packing box my tool from Hoye came in.!!{******} otherwise I would ship it to you..
They rent it for 10.00 for 10 days.. but u have to pay shipping.$$.
The way I figured it, it was {almost}cheaper to buy it, rather than pay the shipping back & forth.. I think it worked out to something like 20-25.00 more to actually BUY it.
Its a BIG slide hammer w/ a special adaptor to screw into the nozzle nut after u have unscrewed the body{top}
BE CAREFUL NOT TO CRUSH THE THREADED PORTION of the body when attempting to turn it.!!!
ITS VERY SOFT METAL.. if u do, theres little chance of fixing it..
I actually took the line OFF THE PUMP & screwed it into the body for support.. & still ended-up HAVING TO BUY the tool..
IT WAS S. T. U. C. K. !! Don't forget to buy the fiber washers that go beneath the injector also..
The best of luck to you..
   / need 2t90 injection pump #7
Thanks for posting that real world experience with the injector puller. It looks like there's going to be a need for one in my future with this YM165d.
When I closed down my mechanical business I kept twenty or thirty favorite pullers, but we did tranny & running gear mostly & never did have an injector puller.
rScotty
   / need 2t90 injection pump #8
I ended up buying one from Hoye a few years ago before I removed the injectors in my 2201d. I waited for the puller to come before I started working on it and when I went to go pull the injectors they came out just by pulling on them with my fingers! Go figure, but maybe the purchase warded off the evil spirits. So anyways I have a new puller sitting in my tool box. But glad I had it just in case.
thanks! do i have to take the studs out? what about getting the prechambers out?
   / need 2t90 injection pump #10
I should probably tag this as 'Humor' :) - but here's my story using materials on hand to cobble up an injector puller.
https://www.tractorbynet.com/forums/yanmar/171020-injector-removal-tool-cheapskate-version.html
They were stuck so hard I couldn't rotate them with jumbo slip-joint pliers. They were an extremely hard pull all the way out.
One tip: when re-installing, coat the sides with anti-seize so they will come out next time.
One of the photos in that post.
164211d1273004227-injector-removal-tool-cheapskate-version-p1590754rinjrem3-jpg
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
Kubota R520S (A50120)
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50322)
2017 Taylor-Dunn...
