jimg
Veteran Member
- Joined
- Jun 5, 2003
- Messages
- 2,039
Im looking for info for the title tractor. Ive poked around
online but couldnt find the following:
1) width at the back wheels (r1s are fine)...I assume this is
the widest point. Was it an option to get other than r1s?
3) Is power shuttle only available w/ the 12x12 transmission?
4) Of the 2 transmissions which would be best for all around farm use
12x4 or 12x12? I was thinking about using it as an all around utility
tractor to haul wagons (loaded w/ hay), mow (brush not hay), rake, ted,
load, till (w/ a tiller not a plow).
5) The power shuttle allows you to reverse w/o clutching and before
coming to a complete stop? How is the power shuttle
implemented...eletrically etc?
6) How common are parts? Easy or hard to get?
7) Are there any 'signature' weaknesses w/ the tractor in general?
8) Is the Ford loader frame mounted? Is it quick detach?
9) Whats the lift capacity at the bucket of the Ford loader?
10) Are rear remotes a possibility?
For anyone who owns this tractor what are you using it for? Whats your over all opinion of it? Anything you dont like about it?
