Rotary Cutter Neapco shaft & slip clutch on Woods MD184
   / Neapco shaft & slip clutch on Woods MD184 #1
bigsnowdog
Deere 5500 Kubota L245DT, Ferris 3100
I have a Woods MD184 rotary cutter. There is a slip clutch that is part of the PTO drive assembly. I need to disassemble it to replace the friction discs.
My first concern is removing the guard from the Neapco driveline. I can't see how it comes off. I have read in other threads where you put screwdrivers in some physical features and unlock something. I find three places I can put tools in, but my visual inspection of the assembly is telling me that won't work. I would like to disassemble and remove the guard without destroying it.
How do I get that shield disassembled and removed? I have slid the PTO shaft apart in to two sections.
My other question has to do with the slip clutch. It appears you have to disassemble one of the U-joints to get the slip clutch completely apart. To do that will be quite cumbersome, holding all those pieces in my big vise. Am I missing something here?
I would appreciate anyone's input on guard removal and slip clutch disassembly.
Thank you.
I got it.
   / Neapco shaft & slip clutch on Woods MD184 #3
I got it.
Maybe you could provide the procedure steps you used for removing the guard and disassembling/reassembling the clutch and reinstalling the guard?.... cause you know that someone someday is going to be searching for that same info :) And I'm curious to know how you did it.:D
   / Neapco shaft & slip clutch on Woods MD184 #4
Bigsnoedog
I have a M54-4 that i am rebuilding and used the parts list on Messick's for my disassembly. I also down-loaded a repair manual from Woods Webpage. Good luck!
shtrndbob
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
PALLET OF NEW HOLLAND PARTS (A51248)
PALLET OF NEW...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
