Natural Gas Pressure?
   / Natural Gas Pressure? #1
Botle
USA
I realize that this is not tractor-related, but I feel that I might get a better answer(s) here... Surely you understand.
We use natural gas for heat, water heat, and cooking. I've noticed a problem when lighting the burners on top of the stove at times during the last eighteen months or so. This is very intermittent. Our stove has electric ignitors and you turn the burner to high to start the gas and back to "ignite" to get a flame. Usually you turn the knob and the burner lights as it should. BUT, there are times when you can't get it to light. When this happens it sounds as if the gas it over-pressured, and the only way to light it is to turn the burner down to the lowest setting and use a match. Even then the flame won't go all the way around the burner. If you turn it up it seems to blow out. After a few minutes of burning like this it gets back to normal. I'm aware that the stove has a pressure regulator on it that should control the gas flow, but I'm not sure if this is a problem with too much pressure in the line from the company or not. It seems as if there's too much pressure, but it also seems like what's coming out isn't gas because you can't get it to start. Is there anyone here that can give me any ideas? I'm going to call the local gas company next week about it, but I don't want to be scammed. Thanks.
   / Natural Gas Pressure? #2
The presure going in to your house is 10 WOG then is brought down to 4 WOG in your stove. I'm betting your burner is dirty.
   / Natural Gas Pressure? #3
That depends on what the gas co supplies to his home. It could be a 2 lb- 6'' wg or wc system or even a 5 lb system. In my area you can have 1 of the 3.
   / Natural Gas Pressure? #4
Your furnace is set at 4 WOC I do this for a living.
   / Natural Gas Pressure? #5
I'm with "murphy" on this, clean your burners first and it will probably fix the problem. Then call the appliance repair guy if that doesn't work.
   / Natural Gas Pressure? #6
could be gas / air mixture is out of adjustment. could be that the burners are stopped up at the point of ign. Burners will stop up when something has been allowed boil over or just from grease. You will need a manometer to measure inches of gas pressure after the appliance reg. to know if the pressure is correct & yes 3.5-4.0 in.WC (water column) would be the ideal pressure
   / Natural Gas Pressure? #7
I'm another one on the side of Murphy1244. If something were wrong with the gas pressure, it would have an effect on everything in the house rather than just his cookstove. If his water heater and furnace work normally, it's a very good bet that the supply pressure is just fine.
   / Natural Gas Pressure? #8
I don't know anyone that said murphy was wrong. I just stated that depending on the gas supplier he could have more than 10 WOG ?? comming into his home. The gas co around here will supply 6'' WC, 2 lbs or 5 lbs to you depending on your application. I don't know anyone in my area that will supply you with 10 WOG ?? In my 30 ?? yrs of HVAC, plumbing / gas. Never heard the term WOG used. We use lbs or 6'' WC
   / Natural Gas Pressure? #9
WOG = water oil gas if it's stamped on a valve etc.:thumbsup:
   / Natural Gas Pressure? #10
WOG is a pressure rating (typically max) for valves, regulators and such.
For example a valve may be rated 600psi WOG, which means the valve is rated 600psi for water, oil or gas.
There is no actual pressure measurment of wog, typical measurements are "wc (inches water column) or "Hg (inches mercury). Others measurements include mmHg, torr, bar, psi, psig, psia and even sometimes ounces.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
