Narrowed Down to JD 3032e and Bobcat CT235
   / Narrowed Down to JD 3032e and Bobcat CT235 #1
renegade13
Calgary, Alberta, Canada
As the title says, I've narrowed my choices down to a John Deere 3032e and Bobcat CT235. Their prices are pretty close with the Bobcat coming in a few hundred dollars less. Both tractors have pin on loaders. I'm looking for advice as to which I should choose. It will be used primarily for snow removal with the FEL and a rear blade.
Thanks for your help.
   / Narrowed Down to JD 3032e and Bobcat CT235 #2
If you ever want to get forks get the JDQA instead of a pin-on bucket. As I recall it is a very nominal amount to upgrade.
   / Narrowed Down to JD 3032e and Bobcat CT235 #3
Get the Bobtach or whatever Deeres name for it is
You do not want pin on, the quick attach is deff the way to go.
There are some horror stories on here where it takes half an hour plus to get the pin attach hooked back up
I can have my bucket off in 30 seconds and have my pallet forks back on in another minute.
(btw I would go Bobcat)
:D
   / Narrowed Down to JD 3032e and Bobcat CT235 #4
Ditto on what lilranch said.
   / Narrowed Down to JD 3032e and Bobcat CT235 #5
Think Green. :thumbsup:
   / Narrowed Down to JD 3032e and Bobcat CT235 #6
Personally I'm a Deere guy. Everyone around here is green. My only really close dealers are Deere and Kubota and the Kubota dealer is known as a *ss so this town is mostly green. Very good machines. I wouldn't buy a Bobcat just because they are rebranded Kioti's. If I wanted a Bobcat I would get a Kioti as they are the one who actually designs and builds the tractor. The 3032e is a great machine and sure you would be happy with either but I would go with the 3032e.
As others have said though get the quick attach system. I only have a bucket on for my 3120 but I take it on and off all the time to do stuff like put a chain around the QA system and hook it to something to either lift something to move it around or pull something like a stump up but it offers much better visibility w/o the bucket on it. JUST GET IT!:laughing: Worth the money. I take it on and off all the time. Pull two pins and tilt the bucket on and the reverse to put it on. Super simple. Wouldn't realize how much you use it until you have it.
   / Narrowed Down to JD 3032e and Bobcat CT235 #7
Get the Bobcat with bobtach... easy to get implements later :thumbsup:.
   / Narrowed Down to JD 3032e and Bobcat CT235 #8
I am not going to advise you on the tractor brand, but I would like to echo what the others have said about getting a quick attach of some kind. Either the BobTach or the JD system.. You will be glad you did later. You will pay more later to get it and you will want it. Just me 2 cents.. Good luck on what ever you decide..
James K0UA
   / Narrowed Down to JD 3032e and Bobcat CT235 #9
A Bobcat is not a Kioti any more than a Kioti is a Bobcat
Daedong- Korea makes both tractors
Deeres in many cases are just rebranded Yanmars, what is your position on that?
   / Narrowed Down to JD 3032e and Bobcat CT235 #10
Not to start a debate about this but the entire tractor is made off of the Kioti frame and chassis and is fairly well identical besides paint. You will even here of bobcat owners getting scratches on their machines and it being Kioti orange underneath. To make the same example with John Deere, John Deere owns hitachi construction who makes excavators. They are identical except color. Not that it matters I would just prefer the original. No real reason beyond that. One of the rare situations that the bobcat actually has a bigger brand name than the who they are having the tractor made by, Kioti. In the case you mention with a John Deere actually being a Yanmar because it has a Yanmar engine is like saying if you pull a duramax diesel from a Chevy truck and put it in a ford the ford becomes a Chevy because that's the engine it has. Kioti makes bobcats frame, the hood, the cab, the ROPS, the loader. They make the whole tractor. Yanmar makes an engine and John deere designs and builds everything else. The loader, frame etc. Not that bobcat/Kioti is a bad thing. If I were to get either of those I would get a Kioti. If I were to get any of the three I would get a Deere. But now were completely off topic.
And btw. Deere makes its own engines for most of its tractors on the 4x20 series and up.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
