Narrow Skid Steer
/ Narrow Skid Steer #1
RichZ
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
I need a skid steer to clean my goat barn, which is a 200 year old dairy barn. I need a skid steer that is less than 5 feet wide, including the bucket, and I need the cage to be as low as possible, too. I'd prefer to buy one used. It's not going to get much use other than barn cleaning, as I have tractors to do the rest of my farm work.
Does anyone have any suggestions as to what manufacturers and models would suite my needs.
Thanks!!
/ Narrow Skid Steer #2
I knew of a small Deere that was probably no more than 3 or 3½' wide, and I believe there was a small Bobcat as well.
The small Deere was on a farm my Dad had connections to, and he always wanted me to buy it and get it running again. Just didn't have the time, nor the need. But it was for sure narrower than your 5' limit.
/ Narrow Skid Steer #3
Case used to make the 1825. It came in both a diesel and gas versions. They were geared for four foot openings.
Bobcat also made a small skid steer.
The 1825 had about eight hundred pound capacity. And they were almost bullet proof. You should be able to find a good one rather reasonably. Try the heavy equipment search engine on trucktrader.com
/ Narrow Skid Steer #4
You want a Bobcat-463 or equivilant. I have used that model Bobcat, where I had a 36-1/2" gate opening. It is 36" wide; I squeezed thru the gate with 1/4" to spare. It worked out nicely. I believe it had a 20hp or so diesel. At 6'2", I thought I would not fit in it, but all worked out well. One thing of note, it does not use standard attachments(They'd be too big and heavy). It uses a smaller attachment group that is shared with thier walk behind unit.
I have used a second machine, that I swear by; it is awesome. That is the ASV RC30. It is a 30hp tracked loader. It is 48" at it's widest, is short in height, and is a real workhorse. I have used a number of skidsteers, and another larger tracked loader. The RC-30 is the greatest thing since sliced bread, IMHO /forums/images/graemlins/wink.gif One thing too about the RC30, it works great in wet conditions...
/ Narrow Skid Steer #5
I'd also recommend something of this nature -- Case 1825B or Bobcat 553 or Thomas 95. (48", ~900 ROC machines with about 25HP. These figures are give or take a few units.) If you go down one step, you'd be looking at RobertN's suggestion of the Bobcar 463, NH 120/125 (gas vs. diesel), and I think that's it.
If you'll be on hard floors most of the time, I dunno for sure, but I think a 553-size machine would be your best bet. There is no doubt you will get more of a RC30, but I think the tracks might not be an expense you need. ($tracks > $wheels.)
However, if you are open to increasing the use of your machine, mainly outdoors on non-abrasive surfaces, the RC30 would certainly be a good idea (though more expensive up front).
/ Narrow Skid Steer #6
I won't disagree with any of the prior posts. Contact a local dealer, especially if you are going with a used machine. Used skid steer loaders can be a perfect example of inheriting other peoples problems.
In your area, I'd try Salem Farm Supply since they have access to both Case and Gehl machines. Both Case and Gehl made narrow skid steers since the 1970's.
Also, call Capital Tractor in Greenwich. They likely have experience with the New Holland L250/L255 and LS120/LS125. These New Holland machines have been produced for years as well.
/ Narrow Skid Steer #7
Why not consider a Power Trac 180 which is 42" wide, 83" long, has a 42 or 45" bucket and no ROPS so you would not have the head room problem.
/ Narrow Skid Steer
Junkie, those are exactly the dealers that I was planning on visiting. I know them both well.
You seem to know Washington County, New York awfully well for someone who lives in PA!!!
/ Narrow Skid Steer #9
I've even been at both dealers...years ago, however.
/ Narrow Skid Steer #11
Hi Rich--My Case 1816 is 30 years old, the wheels are dished so the width can be narrowed to 36", or 40+ at the more stable setting. 16 hp gas is not enough engine, the next generation was 18 hp gas. Get a diesel, unless the barn is not well ventilated. Newer diesels burn fairly clean, especially the Kubota engines that are in many small skid steers. Note the small wheels on the 45X and 46X Bobcats. How rough and how soft is the path to the manure pile? Search on e-bay to see the age and variety of models. I didn't say buy. Search for "skidsteer" and "skid steer", sort by price from high to low. For low ceilings, look at the stand-on models made for landscapers. You stand-up on a step that is 6 inches off the ground--no rollbar needed. Lawnsite.com has extensive postings about skidsteers. Joe
Compost?--Bin there, dung that.
/ Narrow Skid Steer #12
How much do you clear? Bobcat makes a tracked loader you stand or walk behind, as do a few other manufacturers. I know alot of older bobcats are also very small(but are probably more dangerous)
/ Narrow Skid Steer #13
My RC 30 is a work horse. I run it on concrete 80% of the time and the track performance is much better than tires. I had rented tire machines in the past but then 2 years ago I rented an RC 30 at Home Depot. I bought one the next day. I have over 1600 hours and I will run the tracks another 400 @least. The only wear is cosmetc (nicks and cuts). This wear doesn't effect the RC 30's performance one bit. The higher price
(tracks vs. tires)
is 100% worth going with.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64280)
KNOW BEFORE YOU...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
(2) HAY TEDDER WHEEL RAKES (A64280)
(2) HAY TEDDER...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
