Narrow FEL bucket
   / Narrow FEL bucket #1
Anonymous Poster
Epic Contributor
I'm about to purchase a JD 4115 with a 410 loader. We live on a small horse farm. I'd like to be able to dump loads of bedding directly into the horses' stalls (this would eliminate alot of manual labor), but all of the FEL buckets that I have seen are too wide. Does anyone make a narrow bucket that would work for this. How difficult/expensive would it be to have a standard bucket narrowed? The doors are approximately 40" wide. Thanks for your thoughts.
   / Narrow FEL bucket #2
Any decent welding/fabricating shop should be able to narrow a standard bucket or custom make one with larger capacity. (bedding is straw yes? Lightweight stuff anyway) If going this route, I would either get two factory buckets and have one modified or get one factory bucket and have another custom made. Custom will probably be more expensive but you might end up with exactly what you want instead somthing that "sorta works". YMMV
   / Narrow FEL bucket #3
Ok, so how wide are the loader arms on a JD 4115?
   / Narrow FEL bucket
Okay, it turns out that the doors are almost exactly 48" wide, so I'm not as tight on space as I thought. Are there any standard buckets that are narrower? The bedding is wood shavings (lighter than sawdust).
Thanks
   / Narrow FEL bucket #5
I have seen 42 inch buckets used for this that were factory buckets. You can have a bucket made as small as you loader arms are wide.
   / Narrow FEL bucket #6
People used to look at my loader funny until they seen it in action.
<A target="_blank" HREF=http://cedarranch.home.mindspring.com/ford3600.html>http://cedarranch.home.mindspring.com/ford3600.html</A>
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2018 John Deere 333G Track Loader (A53485)
2018 John Deere...
2021 KOMATSU D71PX-24 CRAWLER DOZER (A52707)
2021 KOMATSU...
Estate Equipment Auction 9/27/2025
Estate Equipment...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
