Oil & Fuel NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #1
rider7767
Platinum Member
Paris, TN
TYM T264 with loader and implements
Many of us have struggled with finding a suitable hydraulic oil for our Kioti's in local markets. I have used NAPA Premium Heavy Duty Tractor Hydraulic and Transmission Fluid for a few years in my old tractor and now in my new Kioti. It is not the cheapest, but it is reasonable plus you know what you are getting. The mulit grade hydraulic fluid specified in my owner's manual are hard to find. I found the tech line for NAPA's hydraulic oil. After calling, these are the oil specs. I also put the tech line info below. Note: this is for U.S. markets.
Part number "NHF 85405" five gallon bucket
Grade 10W-20
cSt at 40ーC (104ーF) 58.00
cSt at 100ーC (212ーF) 9.43
Pour Point (ーC):by ASTM D 97 -32
API Gravity 31.3
Boiling Point: Not determined. Expected to be > 260ーC (500ーF).
Specific Gravity @ 15.6oC 0.8692
Density @ 15.6oC 7.237
View attachment Lubricants-Chart-2012-07-20.pdf
Cross Oil
Customer Service Representatives: Tina Estridge & Terry Jones
Direct: 800-343-6361
Fax: 870-864-8661
Cross Oil - Contact Us
Thank you Terry at Cross Oil for the info. I hope this helps the KIOTI community. :salute:
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #2
TSC Traveller Universal Tractor Trans/Hydraulic Fluid
Traveller Premium Universal Tractor Trans/Hydraulic Fluid is a specially formulated, premium multigrade (SAE 10W-20) fluid
Additive Type - Premium
Flash Point - 435 deg. F
ISO Viscosity Grade - Multi-Viscosity
Pour Point - -44 deg. F
Size - 5 gal.
Viscosity (SUS @ 100 F) - 400
Brand - Traveller
Mirrors the NAPA
Flash Point - is same as boiling point
Size - 5 gal.
Brand - Traveller
Mirrors the NAPA
Both will fit the bill; however, NAPA has over 6000 locations, to TSC's 1200+. People should be able to get one of the oils.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #4
TSC will ship $4.99 to your door, don't have to leave your house. Now that beats driving to NAPA.
Go TSC!!! :applause::applause::applause::applause::applause::wave: Too Funny, but that is a good point. Gas is high!:thumbsup:
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #6
I hope its right, I'm picking up three buckets tommorow.:confused2:
Its kind of confusing, is says on the Material Safety Data Sheet
NAPA PREMIUM TRACTOR HYDRAULIC FLUID
Gravity
by ASTM D
1298
THF J20C
10W30
I don't get it, the Martins guys says 10-20 but the msds says 10-30?
Gravity
by ASTM D
1298
THF J20C
10W30
Call Terry from Martin above. He is one of the Oil techs who can answer your concerns. When I talked with him, He sure did not sound as if he was guessing. I would guess the product has changed to keep up with the new machine requirements, and they have not updated the MSDS sheet. I also emailed their customer service center asking for the most up to date full specs of the oil. I like stuff in black and white. I will post their reply.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #8
I am fortunate in that I drive right by both a tractor supply and NAPA on my way to work...
That is in addition to Advance Auto Parts, Auto Zone, Reilly's, Wal Mart, Lowes, Home Depot, Northern Tool, Harbor Freight...
No wonder I stay broke...LOL
In all seriousness, we've been using tractor supply products for years with good results...
NAPA carries excellent parts and oil also...
Lowes and Northern Tool would do me in. :dollarsign:
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #10
Yeah NAPA and TSC are both great companies and both have good products.
When I had the Kubota the shop here wanted $400 for oil change at 50 hours, I did it for $150, a lot of difference, priced out oil and TSC was the best price.
Just a FYI, anytime doing shopping on the net at places do a search for "Coupon Codes" "name of store", most have a online coupon code that you enter at checkout, might be 10% off 15% or more, or free shipping, never know some don't have any codes some do. Just a tip to save a few coins.
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
Sims Snow Board (A51573)
Sims Snow Board...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
