NAME THAT SOUND
   / NAME THAT SOUND #1
8ntractorjdx
Nova Scotia
Kubota B2301
recently purchased farmall 200 changed distributor gas tank tuneup adjusted valves with help from dj56 it sounds many times better and has a lot of power but what is that high pitch sound sounds like broken glass bouncing in the engine that occasionally happens you can hear it best at the near the end of the video; is it ok to run this way? thanks
   / NAME THAT SOUND #2
Is it up front near the fan belt and stuff driven by the belt?
   / NAME THAT SOUND
yes it sounds like the front or in the engine. The video sound is not that good but the sound is a loud snap like something is bouncing around in the front of the engine. I just had the valve cover off and there were no broken push rods or any other parts that I could see. I will try to get a better recording of it. The engine ran so bad before that i did not notice it. now that the engine is at least able to run on its own and it is quieter this sound became more noticable. thank you
   / NAME THAT SOUND #4
If you have a wooden dowel, about the size of a broom stick, or slightly smaller around 18" - 24" long, you can put one end one various area's, and putting your thumb over the other end, then up to your ear, making contact with your thumb, that make's a poor man's stethoscope. Really amplifies sound from a select area. Just be careful not to get it caught in the fan.
I'd try the generator first, then the bracket that holds the fan assy. If nothing there that sounds familiar to what you're hearing, start at the top on the valve cover, and work down, Gov. assy. etc., front to back, and both sides.
I can't remember if this was the thread that had asked about lubing the fan hub assy. or not, but so remember answering to one lately here, or on another forum. If not this one, there is a screw on the round part of the fan assy. It's a round head, and maybe 3/8" across. It has a rubber washer under it. Rotate the fan until the screw is to the side. Remove, then fill with a light weight oil, until it runs out. Let it set a bit, the rotate the fan until the hole is straight down, to drain excess oil. Rotate back to where you can re-install the screw, then try it.
There should also be two small oil fill caps on the generator. Just one pump from an oil can should be enough on those, if they haven't been lubed since you got it.
Between my hearing, and the speakers I have, can't really hear it real well. What I thought I heard though, was something in time on the exhaust stroke through the muffler.
   / NAME THAT SOUND
Hello DJ54
I will try the dowel. I just put the alternator on today just picked it up from the rebuild shop. I did lube the fan hub about a week ago. a lot of white oil came out and I just kept adding running and draining until it was closer to oil color. I had the fan belt pretty tight and when I put the alternator on I loosened it to spec I also put about 1/2 a can of spray seafoam through the carb and finally hooked up the cleaned up air filter. added seafoam to the oil and gas. the motor sounds really good other than that funky snapping sound. I have the brake assembly off and I am waiting for the seal hopefully next week. then I can change the gear oil and run the tractor for a while thanks again for your advise and help
   / NAME THAT SOUND #6
you can do the same with long screw driver. Easier to hold and the handle fits the ear better.
   / NAME THAT SOUND #9
Agree with the HF stethoscope, makes things much easier. When you did the fan hub did you check it for excessive play? I've had water pumps make a similar sound when they got sloppy. I'm sure that you've already checked to make sure that the fan isn't contacting a bit of floppy sheet metal or any debris in the bottom of the shroud.
   / NAME THAT SOUND
thats a good suggestion I will look at that in the morning. the sound only happens occasionally. There is play in the fan hub. The stethoscope is a good idea I will look into it. thank you for your help. I will let you know what I find .
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2013 CATERPILLAR D6T LGP DOZER (A51406)
2013 CATERPILLAR...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
