Nail hole in tire repair
Status
Not open for further replies.
   / Nail hole in tire repair #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
I got a nail into a front tire on My NX6010 that is filled with Rim Guard.
what is the procedure for repair?
Can I drill it out and plug it, or must I break the wheel down and patch it like a bias ply tire?
   / Nail hole in tire repair #2
I would sure try the plug first, what do you have to lose? I wonder if it will work, the plugs have an adhesive coating.... Probably should roll the tire where the hole is on top, let it sit for a few hours to drip dry internally. Let us know!!
   / Nail hole in tire repair #3
Rim guard is non corrosive so i don't see what the problem with a plug would be I'd it holds the pressure. Calcium you don't want on your rims between the tube and tire/rim, but you don't have that issue.
What I'm hoping for is the best practices on a professional level, not guessing.
   / Nail hole in tire repair #5
I would suggest that you specify that you only want professionals to respond in you original post. Sorry I took the time to click on your thread. I am unsubscribing next.
   / Nail hole in tire repair #6
I thought I made myself clear when I asked, "What is the procedure for repair?"
In other words, how do the equipment tire pros do it?
If asking for the correct procedure is offensive, then I don't know what to make of your reaction.
   / Nail hole in tire repair #8
Mr. Oracle,
It's a small hole in a tire. You have three options. 1) plug the tire. 2) patch the tire. 3) discard tire and replace with new tire.
It's obvious your deity / god has let you down or you would received the foreknowledge to swerve and miss said nail on the trail.
I will stop bowing before your highness now and will be leaving.
Mr. Oracle,
People: asking for the procedure that pros use (best practices) is not grounds to take offense or make attacks against my person. I really don't know and simply wished to learn to know the procedure.
For example: If equipment tires aren't radials, a plug will not hold.
Clearly i shouldn't have bothered to ask a simple question on this forum and I should have waited until Monday and called RDO.
   / Nail hole in tire repair #10
You STILL just don't get it.:confused3:
You seem to think asking: 'what the procedure is' to repair a front tractor tire is eliciting only professional answers, then you're definitely in the wrong place/forum/website.
Sometimes one may get a pro's opinion on some question; less often than member's thoughts, own methods/techniques, etc.
You want pro only best practices, go to a professional truck tire repair and give members here a break from your inability to understand how members here tick. JMPO.
Status
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
NEW HOLLAND TN75SA TRACTOR (A51247)
NEW HOLLAND TN75SA...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
