NAA Pulley Question - Continued and Water Pump lea
   / NAA Pulley Question - Continued and Water Pump lea #1
Ortis
Maryland
While I did not ask for an alternative, alternatives are always appreciated. Thanks. That's what engineering, and creative repair of old things, is all about. The tractor had a narrower belt when I got it, and it was indeed overheating. I found the belt was loose, so I tighened it. It worked for 15 minutes and snapped. I suspect a new, narrow belt would work for a while.
Addendum- Now I see I have a drip from the water pump onto the belt, which I bet is not helping. I assume that the ONLY answer to that is a new pump. Any creative alternatives out there?
   / NAA Pulley Question - Continued and Water Pump lea #2
that drip is the pee hole. It is telling you a seal is letting loose. In an emergency, say.. you needed to finish plowing that week.. you could dray and glob the hole up with rtv.. finish work.. then rebuild / replace the pump.
Can't let it go long. Generally a seal failure is either evidence of a bearing failure ( that lets the seal wear).. or is in advance of a bearing failure.. as the bearing fails after the seal fails. In either case.. you let it go long enough and the fan gets wobbly.. a little more time goes by then the fan suddenly flies forward and cuts a nice round hole thru the 300$ radiator core... /forums/images/graemlins/shocked.gif
your choice on how / when to fix.
Soundguy
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Electric Mobility Scooter (A51694)
Electric Mobility...
2016 Bobcat S850 (A50123)
2016 Bobcat S850...
CAT Skid Steer (A50322)
CAT Skid Steer...
