NAA Pulley Question - Continued and Water Pump lea
   / NAA Pulley Question - Continued and Water Pump lea #1
Ortis
Bronze Member
Maryland
While I did not ask for an alternative, alternatives are always appreciated. Thanks. That's what engineering, and creative repair of old things, is all about. The tractor had a narrower belt when I got it, and it was indeed overheating. I found the belt was loose, so I tighened it. It worked for 15 minutes and snapped. I suspect a new, narrow belt would work for a while.
Addendum- Now I see I have a drip from the water pump onto the belt, which I bet is not helping. I assume that the ONLY answer to that is a new pump. Any creative alternatives out there?
   / NAA Pulley Question - Continued and Water Pump lea #2
that drip is the pee hole. It is telling you a seal is letting loose. In an emergency, say.. you needed to finish plowing that week.. you could dray and glob the hole up with rtv.. finish work.. then rebuild / replace the pump.
Can't let it go long. Generally a seal failure is either evidence of a bearing failure ( that lets the seal wear).. or is in advance of a bearing failure.. as the bearing fails after the seal fails. In either case.. you let it go long enough and the fan gets wobbly.. a little more time goes by then the fan suddenly flies forward and cuts a nice round hole thru the 300$ radiator core... /forums/images/graemlins/shocked.gif
your choice on how / when to fix.
Soundguy
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2017 GMC Sierra 1500 Elevation Crew Cab Pickup Truck (A51692)
2017 GMC Sierra...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
2012 Scion Xb SUV (A51694)
2012 Scion Xb SUV...
42013 (A51691)
42013 (A51691)
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
