NAA overheating?
   / NAA overheating? #1
trimblepa
Hi,
After running for 10-15 minutes, coolant starts to spray/leak from the hose connections, but the temp gauge is only creeping up. After shutting'er down, the guage goes to about half way and coolant dribbles in a small stream from the uppper hose clamp. The thermostat housing is not scorching, but too hot to keep a hand on. I tried removing the thermostat, no change.
Am I right in thinking she's overheating, in spite of the gauge? How to tell if the water pump is shot? Is there a good place to take a reading with a thermometer?
Thanks.
   / NAA overheating? #2
1, if you are getting leaking at a hose clamp.. I'd take em off and check the nips.. may be rusty.. or hoses rotten.
is your lower hose warm?
have you cleaned out the block and radiator?
do this.
drain rad into a 5g bucket.
use a garden hose in top port with cap on... aim lower hose into bucket. it should floaw a full stream of a 1/2" garden hose without overflowing.. if not.. rad may be plugged.
also.. check out core.. can you see thru it. dirty core won't drop heat good. chaff and seeds and grime and dust blocks core.
next.. if you want to test pump. reconnect lower hose, fill rad, remove thermo.. aim top hose out leave rad cap off and have garden hose trickling in it to keep it filled.. start tractor.. see what water moves out top hose.. if not much.. impellor may ne rusted to a nub. not common but DOES happen.
take this time to remove block drain as well and maybee a core plug and backflush block. if a ton of rust comes out. buy 2g of ninegar , drain water.. replug and hose up everything.. add vinegar and no tstat and run and let set.. then drian next day.. back flush again.
if thermo is good re-use. can check in a pot of boiling water.. don't let wife see this....
post back
   / NAA overheating?
Thanks for the excellent suggestions! I'll try them out this weekend (the tractor lives an hour from the house) and post the results.
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2014 Club Car Electric Cart (A51694)
2014 Club Car...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
