NAA Oil Leak
   / NAA Oil Leak #1
Glenn_M
Cambridge, Ontario, Canada
Kubota BX 23, Ford NAA, International B414
I have a Ford NAA and at one time there was a loader on it. I removed it a long time ago but the valve is still on the tractor (see attached photo) This valve changed the hydraulics from the 3ph to the loader. It has developed a leak lately from the area where the yellow arrow is pointing. What I'm wondering is if I can remove that valve and replace the cover with another part or if there is likely a washer or gasket under the nut that may be shot? I also wanted to know if there are any surprises under there if I take a wrench to it?
Thanks in advance !!
   / NAA Oil Leak #2
Glenn,
There is a lift cover plate that can be put there instead of the selector valve. I don't think there available new for the NAA but I imagine you can find one used.
If it's like the later lift cover plate/selector valve then there are o-rings under the valve. Never seen the underside of one on an NAA so there may be o-rings and a gasket. You may want to post your question over on the Ford board at ytmag.com. Lot's of expertise on your tractor there.
HTH
Rick
   / NAA Oil Leak #3
I don't think you will find any surprises, just o-rings as Rick suggested. The plate is called an Accessory Plate if you are looking for a replacement. However, if you remove the cover, you will probably be able to stop your leak with o-rings.
Disclaimer: I do not have an illustration that shows the loader accessory plate like you have. My diagrams just show the standard accessory plate blank, so use caution when removing the plate.
   / NAA Oil Leak
Thanks Jim:
Can you send me or post the diagram of the regular accessory plate? Looking at this one I'm not sure which bolts to remove? The two that have nuts on threaded rods may have something attached on the inside?:confused:
Thanks
Glenn
   / NAA Oil Leak #5
Glenn,
Jim is right the correct term for the part w/o the valve is accessory plate. I've been rebuilding the lift cover on my 4400 and lift cover on the brain. You can access the diagram on the web through New Holland. Here is a link.
https://webparts.pvassociates.net/cnh/webparts/main.php
Just type NAA in the model search box and select the correct diagram from the list.
   / NAA Oil Leak
Hi Rick:
Thanks for the info but the link didn't work?
I would like to just replace the valve with the proper part since the tractor won't have a loader again. I will also need the gasket, I guess I can just order this from the dealer?
Thanks in advance.
   / NAA Oil Leak #7
Glenn, I'm sorry to say that my scanner is temporarily out of service, but Rick gave you much better advice. His link didn't work for me, but the New Holland website at New Holland has the parts diagram you need. Click on Parts and Service in the menu and then type in NAA in the search box. Also, there are many suppliers of Ford NAA parts including the gasket sets with o-rings for your lift cover - YTMag .
There are five bolts holding the accessory plate. You will have to remove all 5 to get your accessory plate off. Three of them with the nuts are for the accessory plate only. The two hex-head bolts not only hold the accessory plate on, but they also go through the lift cover. The lift cover, itself, has about a dozen bolts holding it to the top of the hydraulic reservoir.
BTW: Have you tried just tightening the nut on the bolt slightly to see if the leak goes away?
   / NAA Oil Leak #8
Yep.. just orings under there...
If it was me.. I'd reseal and use the valve as a remote... it's a selector valve style.. but with it you could run a cheap DA logsplitter valve and have DA hyds.. and just plumb the return line to the tank sump by drilling and tapping the hyds sump bung with a hose barb fitting...
remote valves for the NAA top cover are a bit rare.. and thus worth $$.. even that limited selector valve style..
If you do decide to repalce it with the accy cover.. i think I know where one is.
The MPC catalog will show this in detail..e tc.
soundguy
   / NAA Oil Leak
I think I'll just take it apart and re-seal it. I will likely need a new gasket, are they hard to find?
   / NAA Oil Leak #10
Gasket.. yep.. impossible to find.. cuz it's orings.. etc.
NAA937B RING O-Ring, Plate to Cover, Prior to S/N 20900, Years: 01/01/1953-12/31/1954
NAA937C RING O-Ring, Plate to Cover, Prior to S/N 20900, Years: 01/01/1953-12/31/1959
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2004 Ford F-550 4x4 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2004 Ford F-550...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
2017 Ram 1500 Crew Cab Pickup Truck (A51692)
2017 Ram 1500 Crew...
