NAA Generator
/ NAA Generator #1
Ortis
Maryland
Happy New Year to you all.
I noticed that the shaft on my NAA generator had a little play in it, so I took it apart. The front bearing does have a bit of side play and is a bit rumbly. I put some heavy oil in it as a temporary measure, but I know it will need replacement.
Question: can I find the right bearing somewhere and install it myself? It appears to be a press fit on the shaft. Is this a job better left to the pros with special tools? Or do I buy a new one? The brushes, commutator, and rear bearing appear fine.
-Ortis
/ NAA Generator #2
I had a NAA genny rebuilt.. neaw bearings, brushes, and field.. comie dressed.. all for 80$.. I'd guess they might hit you up for 10-20$ if you took it in disassembled and they just had to R&R a bearing.. etc.. Doesn't hurt to call and ask..
( Most of my old ford gennies and starters have been less than 100$ to reman... I'd opt for that vs buying a new import.. )
Soundguy
/ NAA Generator
Thanks Soundguy. I just called around and found a shop that will inspect and repair it for $45 + parts. Sounds great to me.
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A59230)
2007 Mitsubishi...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
