sashooter
- Joined
- May 19, 2015
- Messages
- 47
- Location
- Twin Cities, MN
- Tractor
- 1953 Ford Jubilee 2020 Kioti CK 3510SE
I'm having trouble now with the tractor. It will start fine and idle great, but then it will just begin to loose it self and quit. I let it sit for a couple seconds start it, and it does the same thing, over, and over.
I took off the sediment bowl cleaned the screen. Screen wasn't dirty anyway. Put it back together turned the gas on and watched the bowl fill up. There was a steady stream of fuel coming out, then it would drip fast, then stream again. There should be a steady stream of fuel till the bowl is full correct?
I did check for spark by taking off the coil wire to distributor cap off. Grounded it to the frame. Turned key on. Pushed starter , and had spark there.
Funny thing is it started and ran that way for a few second till I shut it off. Still did the same thing. Can they run with the coil wire grounded to the frame?
Actually now that I think about it, I should of disconnect the plug wires off first. Right? Then check spark from coil.
