N100D for all transmission and lifter and front axle.
   / N100D for all transmission and lifter and front axle. #1
Lodi
walworth WI.
Lu Zhong
Hello and good day
The manual for my Lu Zhong 254 says to use
N100D oil for everything. I have manual transmission.
What oil(s) do you all use for transmission and lifter?
Also, can anyone please tell me if the the transmission
and rear axle use the same drain plug?
Thanks for your time
   / N100D for all transmission and lifter and front axle. #2
Looks like its just AW100 oil.
Thank you for kind reply.
Is it acceptable to use GL-4 80w-90 gear oil??
I don't want to damage tractor.
Which one is better? AW100 or 80W-90?
Thanks
   / N100D for all transmission and lifter and front axle. #4
AW100. The viscosity of 80W90 at 40C is north of 140. Use what is recommended not a substitute.
Okay. AW100 I will use.
All of the other Chinese tractor forums that I found recommend GL-4 80W-90.
But from reading my manual, it doesn't sound like this
tractor was meant to run 80W-90 gear oil.
So I will use the AW100.
Thanks for you time.
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
3in Poly Pipe (A49461)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
Unused 2025 CFG NT18K Mini Excavator (A49461)
Unused 2025 CFG...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
