N100D for all transmission and lifter and front axle.
   / N100D for all transmission and lifter and front axle. #1
Lodi
walworth WI.
Lu Zhong
Hello and good day
The manual for my Lu Zhong 254 says to use
N100D oil for everything. I have manual transmission.
What oil(s) do you all use for transmission and lifter?
Also, can anyone please tell me if the the transmission
and rear axle use the same drain plug?
Thanks for your time
   / N100D for all transmission and lifter and front axle. #2
Looks like its just AW100 oil.
Thank you for kind reply.
Is it acceptable to use GL-4 80w-90 gear oil??
I don't want to damage tractor.
Which one is better? AW100 or 80W-90?
   / N100D for all transmission and lifter and front axle. #4
AW100. The viscosity of 80W90 at 40C is north of 140. Use what is recommended not a substitute.
Okay. AW100 I will use.
All of the other Chinese tractor forums that I found recommend GL-4 80W-90.
But from reading my manual, it doesn't sound like this
tractor was meant to run 80W-90 gear oil.
So I will use the AW100.
Thanks for you time.
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2015 John Deere 35G Mini Excavator (A49461)
2015 John Deere...
2021 Snake River 14K Dump Trailer (A49461)
2021 Snake River...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
