N H Ford 445C TCM no. FONN7Z319AAR.
   / N H Ford 445C TCM no. FONN7Z319AAR. #131
I just kind of temporarily put mine up under the dash above where the pedals are. Only one bolt in each to hold them there, in already existing holes. I haven't gotten around to a more permanent mounting yet.
My turn. Buddy says hi.
   / N H Ford 445C TCM no. FONN7Z319AAR. #132
Ok, here is the pinout and connection guide for my 555D using 2 controllers, one for forward and one for reverse. The controllers are "Hanlei CCM-TK." This will allow the machine to function just as it originally did with the shuttle lever. Merry Christmas! Be sure to check your individual machine's schematic to be sure your wires are the same before using these colors! I attached photos of the controller terminals so you can see the labeling of the terminals as well as the two plugs that I sourced from the original TCM. Follow the connections in the 2nd image with the text, ignore the connections in the controller terminal image - that is currently set up for my temporary drive method that uses the toggle switch rather than 2 individual controllers. All of the original safety interlocks should still function with this setup if they were active and not previously disabled, as the power for both the brown and gray wires (FWD and REV signals) comes off of the red wire, which gets shut off if any of the interlock contacts are broken in the electrical path. If any of those were previously disabled, they will still be disabled.
My 545D with lockup is exactly like yours.
   / N H Ford 445C TCM no. FONN7Z319AAR. #133
8x8s should all be the same.
Nice to have a workaround
   / N H Ford 445C TCM no. FONN7Z319AAR. #134
Hello guys. So, finally I'm doing the bench test before transfer to the tractor 🚜.
In the setting #1 I just increase the value one point, everything else is at default.
This is correct?
   / N H Ford 445C TCM no. FONN7Z319AAR. #135
fred saas this company repairs tcm's
fred saas this company has many many parts if you ever need
anything else:
willy
   / N H Ford 445C TCM no. FONN7Z319AAR. #136
This is correct?
Controllers get 12.5 solid when engine running. I disconnect black wire 'cause when running and switch on wire get 2v.
Tractor engage momentary then nada.
I'm still on the fight
   / N H Ford 445C TCM no. FONN7Z319AAR. #138
POWER WATTAGE MOTOR NEED TO BE SET TO 60. MY TRACTOR ITS ALIVE! THANKS TO YOU @eKretz @TractorTech
👍 Good deal! Happy to help. Sorry about the lack of response up to now, I didn't get any notifications for these latest posts, just happened to check in and see them just now!
   / N H Ford 445C TCM no. FONN7Z319AAR. #139
Thanks to @eKretz for coming up with a simple, inexpensive solution to save an otherwise dead tractor.
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
