N.H. 6640 three point hitch won't go down
   / N.H. 6640 three point hitch won't go down #1
cashtech
jackson, michigan
ford 6640
I have a 1997 New Holland 6640 cab tractor. I let a friend use it for mowing. He hooked up an offset tiger flail mower and worked well for about 2 days. Then he brought it back to me and let me know that the three point hitch will not go down with the tractor running. If I shut the engine off I can let it down using the control lever. But as soon as I start it the hitch goes up no matter what position the control is in. Also, after a few minutes of running it loses nearly all hydraulic pressure out of the remote couplers. I pulled and disassembled the priority valve and can't find anything wrong.
Any ideas?
   / N.H. 6640 three point hitch won't go down #2
take the priority valve and use a brake cylinder hone to clean it real good and them flush with ether. the priority valve is most likely the trouble
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
