Mystic JT 8
   / Mystic JT 8 #1
TPS
Has anyone ever pulled a UOA on Mystic JT8 15w40 Super heavy duty synthetic blend oil? The tractor store I go to still gets it in CI-4+. I was wondering if anyone used it and if anyone has any numbers on this oil. I was considering using it in my small Kubota and maybe in my older cars and trucks.
Thanks,
TPS
   / Mystic JT 8 #2
Check on bobistheoilguy.com. I think Mystick products get good reviews.
   / Mystic JT 8
Thanks tydp,
I'll try to find some information there.
TPS
   / Mystic JT 8 #4
Thanks,
TPS
I wouldn't mind hearing a little more about Mystik too. All I know is that Citgo makes it and it's been around quite a while. A few of the local stores sell it and I had thought about trying it in the Kubota along with their hydraulic fluid because I can get it locally. I ended up making the trip to the Kubota dealer and just used OEM fluids.
   / Mystic JT 8 #5
I've been using it in my Ford powerstroke... I like it...
It may be all in my head but it seems to run a little smoother than another brand I was using.
   / Mystic JT 8 #6
If you don't mind supporting Hugo chavez, keep buying Citgo products.
I make every attempt not to buy that brand.
7-11 stores quit selling citgo, even though they havent changed all the signage
   / Mystic JT 8 #7
+1
This is the only brand I avoid like the plague. I think the US operations of Citgo are likely to be sold to someone else in the next 1-3 years though.
   / Mystic JT 8
Thanks for the replies guys. Yeah, I found out it was made by Citgo after I bought it. I hate to buy products from them but I read the Mystik line is under some other group now?!? However, they employ a ton of Americans and are headquartered in Houston Texas. Anyway, I wrote them and these are the numbers that they sent me for this oil:
CI-4 plus 15w-40 synthetic blend heavy duty diesel oil:
TBN 11
Pour Point -27 F
VI 139
Flash Point 457 F
Ash 1.1
Zinc 1490 ppm
Phosphorous 1345 ppm
HT/HS 4.1
Noack 12
These actually look like pretty good numbers. The only one I don't like is the noack volatility number. This does not mean as much without a UOA I really would like to know how it holds up under work/time.
Anyway thanks and take care,
TPS
   / Mystic JT 8 #9
Where's the rest of the oil analysis? They only list two additives.
2013 Caterpillar AP500E Asphalt Paver (A52377)
2013 Caterpillar...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
Utility Trailer (A52377)
Utility Trailer...
