mystic jt-5 in LB1914 ??
   / mystic jt-5 in LB1914 ?? #1
electroau
PA, USA
LB1914
What should I use for hydrulic fluid in my LB1914?
What do people think of mystic ? its a TSC, but I have never heard of it ?
Thanks
   / mystic jt-5 in LB1914 ?? #2
I've not heard of it either, but if it meets the specifications for use in your LB1914, then use it. It must have the same classification, or better, than what Kioti states in the manual.
TSC's universal hydraulic fluid is okay to use.
Warren hydraulic products as well. Look at AW46 or AW68.
John
   / mystic jt-5 in LB1914 ?? #4
I couldn't get the site to download. As a matter-of-fact, it just froze up my computer! Probably something on their server not right.
If it says it's okay to use in XX brands of tractor, I'm sure it's okay for yours. Many are "universal" type fluids, designed for a variety of brands.
John
   / mystic jt-5 in LB1914 ?? #5
I found some info on that fluid, and it should be just fine or better than the recommended fluid. John
Thanks forn helping John, I greatly appreciate it !
   / mystic jt-5 in LB1914 ?? #7
I use the Travellers brand from TSC in my CK20. Most fluids you'll find will be/are universal.
   / mystic jt-5 in LB1914 ?? #8
I used vavoline uni-trac hyd oil in my 1914. It's the only one listed in the owners manual I could find. Napa has it for about $40.00 for 5 gal.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53472)
2016 Ford F550 4x4...
