mystery Part Search
   / mystery Part Search #1
timm9
Sierras, CA
Toolcat(s) 5600B-Turbo(s)
Hi All,
I found the following 'part' on the ground after moving my TC to a different location on my property.
I am not 100% certain the part is off the TC but did not work on anything else vehicle or equipment wise that day.
I have done a 'belly crawl' as well as inspect engine compartment and see nothing that would give me a clue.
The part is solid steel with a hole and threads on one end.
Any assistance would be greatly appreciated...:)
   / mystery Part Search #2
It looks like something that limits the movement/range of something else... it reminds me of an old rubber 'doorstop', if it were made out of hard rubber, which you say that it's not.
Wagtail,
Thank you very much for the response.
Initially I thought it was one of the 'hockey pucks' that resides between frame and stop on front frame that have a tendency to fall off. This is solid steel. I'm starting to wonder if it is some type of harmonic 'dampener' associated with the fan assembly???
   / mystery Part Search #4
I agree with Wagtail. Looks like a hard stop for either the front loader or the dump bed.
But on a closer look, the threads seem to have quite a bit of rust. I'm not sure if that happened recently.
   / mystery Part Search #6
Are the threads SAE or Metric?
   / mystery Part Search #8
I thought it looked like an end weight off a sliding hammer
   / mystery Part Search #9
It's definitely been exposed to the elements for quite some time. Could it be an idler or tension pulley off some old belt driven implement? Some of the black residue on the rim kind of looks like my lathe pulleys.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2019 John Deere 8295R MFWD Tractor (A53485)
2019 John Deere...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2022 CATERPILLAR 246D3 SKID STEER (A52707)
2022 CATERPILLAR...
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
