Mystery Noise from ZD326 Rear End When Accelerating
   / Mystery Noise from ZD326 Rear End When Accelerating #1
Suburban Plowboy
FL
Kubota L3710
Today I noticed that my ZD326 seems to make noise when I accelerate using the motion handles. It appears to come from the rear end. It's kind of like a dry door hinge, only, of course, louder. It goes away when I'm not accelerating from a stop.
Any idea what it is? Is the mower about to blow up?
   / Mystery Noise from ZD326 Rear End When Accelerating #2
Have you checked the hydro fluid level? My zd21 has three dipsticks, I'm guessing the 326 is similar.
Wait...three?
Let me check the manual.
Page 47 of the manual only mentions one dipstick, and I checked it a month or so ago, but I'll go back and do it again.
The manual also says to shut down the engine and let it idle for several minutes before checking the fluid. Somebody was hitting the sake when he wrote this manual.
This is embarrassing, but hey, it's not like the Internet never forgets, right?
As I have gotten older I have found that I sometimes make mistakes when trying to locate the sources of sounds. I think that is what happened with regard to the mower. I took it out today, and it looks like the noise is actually coming from the front wheel bearings, which are cheap, unlike the rear bearings, which run about $4,000 installed, since Kubota built the mower around them.
   / Mystery Noise from ZD326 Rear End When Accelerating #5
Each of my drive units has a dipstick as well as the one under the seat.
Man, that is crazy.
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Carlton OX Walk-Behind Tracked Stump Grinder (A55851)
Carlton OX...
19088 (A55758)
19088 (A55758)
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
