My view
/ My view #61
/ My view
My view today... Notice how big the weeds are, they cross over from side to side.
/ My view
That looks like bamboo, is it? Might be a market for that also if it is not the spreading kind. Some folks like it for privacy fencing
Gary I wish it was bamboo.. It's actually called false cane( like in sugar cane) what sucks is that the only way to cut it down is with machete. If you use round up( it kills it) then it won't even take a ninja sword. :-(
If you cut it down then spray it when it's starting to grow you can control it.
I have used weed eaters with both string and blade, tree pruner and chain saw. All it's does is tangle up the machines. I even used one of those Troy built walk behind bush mowers and I lost.
All I can do is when I walk by one is chop it or yank them out.
It's been my biggest battle on the farm.
/ My view #67
I have an easier solution for you than a machete, get a saw blade for your string trimmer and you can slice that stuff like a hot knife in butter. I looked at them at the Stihl shop and decide that $60 was a bit much. I had a couple of extra 7 1/4 Skil saw blades so I found one with the right sized arbor and just bolted it on with some adapters that I had from a string trimmer. It worked great cutting my fence line that was grown up in sawbriar 1/2" thick and small bushes and saplings. It saws thru a 1" sapling with just a touch. It is dangerous machine so be careful. You do need a straight shaft trimmer supposedly but my brother in law used one on a curved shaft without immediate problems. It might wear on the cable but those things are cheap @ $70.
If you want to spend $500 get the Stihl with the bicycle handle bars for greater control. I think Echo makes something similar also.
/ My view #68
Man Gary that sounds scary!:shocked: You be carefull also!
/ My view #69
I've one of the older big stihl trimmers and i have one of the brush blades. I've cut 2" saplings with it!
Where it really shines is cutting the suckers (shoots) from my blueberries. It slices right through that stuff.
/ My view
My weed eater has an attachment for a metal blade... I tried it once and it didn't do much.
Maybe if I put a knife edge on it, it might work better.
If not I will try a blade.
I wonder if the farm has work comp insurance...lmao
/ My view #71
Just moving some stumps wish the machine was mine, for more than a weekend
/ My view #72
Sweet. Question: I have about 100 or so stumps in the ground right now, ranging from 10" to 36". Based on what you "borrowed" for that work, can I get that done in a weekend? I'd love to rent one of those, but all I have around me are mini-excavators and TLB combo machines, and at $200/day, I don't really know how much I can expect to get done with those machines.
That's why I'm leaning towards just buying a stump grinder...
/ My view #73
This was a hitachi zaxxis 135. Great machine, I had about the same amount of stumps and roughly the same size and yes you can do it in a weekend. With probably 8 hrs on the machine. This rents for 395$ a day which I always get my machine Friday morning gives you three days to put 8 hours on it but I generally will be closer to 16, try and organize my projects so I can get max use out of machine. I use my tractor for moving and staging the smaller stumps. The bigger stumps in the 36 d range you will probably have to dig around but the small stuff will pull right up especially if there is a decent amount of stump above ground. A couple rental places around me have blades on these machines as well which helps in filling the holes and leveling after. If you can afford a 160-200 I would think about that as it will tear out stumps even better. Watched a neighbor take out his stumps with a 200. Made the 135 look like a mini you will have a lot of fun though
/ My view #74
my view last summer while move some dirt in my yard near Lake Audubon
and my view after blowing snow for three hours last night.
/ My view #75
btw - really enjoyed going through all these photos! you folks have some awesome properties and very cool toys : )
/ My view #76
Thanks... I'll try to find one to rent. I should probably cut down the remaining trees first though, like you said... I have another 50 or so that I want to get down before I start digging or removing stumps.
/ My view #77
Those little 4 blade things don't do much but still better than a string. I have one of those also but to get the tough stuff, you need a blade like a table saw on it and it cuts just like one too, rev it up, swing it into the sapling, "ZING" and its cut. Just keep the guards in place and be mindful that you have a sharp saw on the end of a stick and you will be ok. I think the ones that you sling around your neck with the handlebars are pretty much fool proof. As long as you have it strapped around your neck, and hands on the bars it cant kick back on you. Make sure any observers stay well back also. I even used mine to de-limb some cedars and sweetgum trees.
I will have to get another carbide blade for it before tackling the fence line again though because I hit too many rocks and old hidden barbed wire with it and knocked off all or at least most of the blade tips. Stihl does make one like a chainsaw on a disc but you know how dirt dulls a chainsaw so I don't think those are very practical.
/ My view #78
A couple pictures with the Big LS cleaning up where I fed the cows rolls last winter.
/ My view #79
Darned cows seem to waste about as much hay as they eat, what they don't stomp in the mud, they crap on and waste even with the hay ring around it the pull out big chunks and stomp on it. If cows are the stupidest creature on earth, then they must not be far behind.
/ My view #80
Well, there IS goats......
They like to CLIMB on the bales... ring or no ring.
My cow was actually pretty smart before I got the ring... she would hook a horn in the bale and unroll it to get to the good stuff!
2024 Deere 320G (A64126)
2024 Deere 320G...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
2017 Hitachi 85USB (A64126)
2017 Hitachi 85USB...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
