My two Stihl's.
   / My two Stihl's. #111
Sorry I was just talking. I like all your thoughts/experiences and none of my remarks carried any negative thoughts. The mods were referring to is like porting and drilling the muffler.
The old bar is really chewed up and worn down so not wanting to mess up my new chain and sprocket I am awaiting a new bar before working the saw. I will get the old chain (some good metal remains) sharpened so I have it and the old bar for crap sawing. :thumbsup:
The saw calls for a 50:1 mix and the blower and line trimmer calls for 40:1 so I have always mixed to cover all of them. Sounds like the HP Ultra oil is high detergent over on the RC plane forum and I can expect black stuff running out of the muffler for the first couple hours of using Ultra.
Stihl Ultra Synthetic Oil
No worries- I wasn't taking offense at all :)
I'd suggest talking to your Stihl shop mechanic about what ratio to use- I've been told to use 50:1 in ALL my equipment, but I only have Stihl and Echo gas engines.
Yes, the Stihl premixed cans of gas/oil are using non-ethanol for the benefits- but I can't see doing it, personally- its a way expensive way to buy gas/oil mix. I just use the ultra and regular gas, not even high octane, and don't keep any stored fuel. I occasionally use Seafoam or Stabil and change spark plugs fairly frequently. If I'm not going to be using a saw for a while I'll drain out the gas into my container marked 'bad gas' and then use it on burn piles later.
From the descriptions of your original bar I'd toss it, or at least have your shop look at it; if it's that beat you might damage your new sprocket, and a chain that's worn out with a bar that's the same will put additional strain on your engine. If you want a stump/dirt bar get a good used one from your dealer or buy something out of Baileys or similar site- keep your 'new' saw happy:thumbsup:
I'd consider using the other saw as your disposable saw and maybe use it with a less than perfect bar/chain to do the 'dirty work, and save the big saw for the heavy lifting.:thumbsup:
And IMHO, I wouldn't worry about doing mods like muffler, porting, etc. until you get some miles on that powerhead and see what it can do stock.
   / My two Stihl's. #112
Yes, I believe that is why you start with higher octane fuel because the oil lowers the octane.
   / My two Stihl's. #113
I run 32:1 in everything (just because I buy in bulk and easy to measure out 4 ounces and feel I get a peace of mind with extra lube) . I ran 32 in the 361 also.
I would run 40:1 in it way before I would run the epa wants you to run 50:1.
Yes if the saw is set up on 50 and you go to 40 you will be lean and have to richen it up.
You do a muffler mod (to release the beast inside the 361) to let it breathe and run cooler you will need to richen up again.
If you mix at 40 to 1 I would do the same for that saw. JMO
   / My two Stihl's. #114
You should use whatever ratio the oil is designed for. The newer synthetic 50:1 oils are meant to be run at 50:1 -- they provide equal or better lubrication to the older oils that needed to be mixed at 32:1 or 40:1. You're just wasting money if you take a 50:1 oil and then mix it in higher concentrations.
   / My two Stihl's. #115
Yes and some oils say to run it at 100:1 and 200:1 but I have a brain to know that I will never run that or the epa mandated 50:1 in my equipment. 40:1 or 32:1 :thumbsup:
Freedom of choice. ;)
   / My two Stihl's. #116
I picked up a new 20" Stihl bar today and another new chain (best to rotate two per the manual). While I have a new 3/8 7 drive sprocket I picked up a 3/8 8 tooth today for the heck of it. It does jump up the size more than I expected.
This used 361 will be within $250 of a new 362 out the door so I am not sure if that savings will be that much longer term over going new. This is after the new bar, two chains and new sprocket plus fuel hose/filter like a new one comes with. At this point I know the used 361 starts well, cuts well and will idle well and can kick like a mule even with the compression release activated.:thumbsup:
One thing I have learned is some who have moved to the 362 that they are not happy with the quality of their carbs but that may be without good cause.
I went with the HP Ultra mix. 5.2 oz was $3 and that made up 1.6 gallons plus the 5 oz of oil to give the 40:1 ratio I prefer for reasons stated above. The son of the owner said while 50:1 was what they were designed to run on that 40:1 built in a safety net and it was preferred by some other customers as well.
Near me I did find an ethanol free 90 octane gas source. The Stihl dealer said ethanol was a major problem with all two cycle engines but it helped their shop stay busy I guess. :(
As a side note the local source has had to bump up ethanol free prices by about twenty cents a gallon. I talked to him today and delivered 90 octane was $3.94 and 93 octane was $4.07 at the moment we were speaking.
Tomorrow I am taking off since the ground had settled back up for the backhoe to dig and push well plus I want to play with the 361 to see if I bought a pig in a poke or got one mean cutting machine.:thumbsup:
So the muffler mod it ready that good?
I do not want to shorten the life of the saw with mods.
   / My two Stihl's. #117
The newest Stihl engines and rev limited carbs are like the 100% synthetic oil, DESIGNED by the manufacturer in accordance to federal law and EPA standards, to comply with current US regulations ~ not really freedom of choice issue so much as a federal MANDATE to keep our air breathable for everyone, not just those who choose to comply. The rev limited carbs are agreed upon by the manufacturers of the carbs and the EPA as a license agreement. Stihl knows what they are doing and at what ratios their saws are intended to run, after all they designed them to run at the ratios allowed by law in the countries in which they are sold.
Nowhere have I seen a requirement to run at ratios of 100 or 200 to 1.
Another example of things done different ways is the AV requirements in the EU and US. The US is less strict and the EU requires more dampening of vibration than the States. Stihl thus manufacturers their saws to comply with the EU AV requirement for saws sold in those countries.
If you want to port/ polish and mod mufflers on saws go right ahead. The average saw user doesn't need to do any of that to get a saw to do what it was intended to do: cut wood.
   / My two Stihl's. #118
I run Klotz 100% synthetic :thumbsup: freedom of my choice. :laughing:
I'm curious to what octane gas you all use with your mix?
   / My two Stihl's. #119
http://www.arboristsite.com/chainsaw/125164.htm
Think I am glad I when with the 361 vs 362 plus I am having fun messing with chains, bars and sprockets. :thumbsup:
On the octane question for the two-cycle gas I go with the highest octane alcohol free gas that I can find. Well not over 95.
   / My two Stihl's. #120
Giyi Telescopic Boom (A57149)
Giyi Telescopic...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
DOOSAN G25KW GENERATOR (A58216)
DOOSAN G25KW...
Giyi Auger (A57149)
Giyi Auger (A57149)
2007 Volvo VNL Truck Tractor (A56436)
2007 Volvo VNL...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
