My Troybilt Horse quit working
/ My Troybilt Horse quit working #1
Yalerider
Woodland, Washington
Branson 3510i w/FEL
I think I have to rebuild the detachable tiller piece in the back. The tiller locks up/spins intermittiently. Does anybody have links or advice on where to get parts or fix this?
/ My Troybilt Horse quit working #3
I have a 1989 Horse that I've been taking care of these 20 odd years. Back in 92 I had a bearing in the main transmission break and back then, I got parts from Troy Bilt. Nowadays, Troy Bilt is owned by MTD in Ohio after the former went bankrupt at the hands of a liability lawsuit due to their "Tomahawk" chipper shredders. MTD still makes the Horse, though the other PTO attachments such as the log splitter, generator, and chipper shredder have all been discontinued, so happily, Horse parts are still available via MTD.
It sounds like your worm gear and/or worm wheel in the tiller unit is gone. Mine hasn't worn out yet, but I think it's time is coming.
There are many models of Horse tillers on file with the MTD parts lookup engine, but the PTO horse model's mechanicals haven't changed much over the years.
Try this link: HELP FINDING YOUR PART
then follow the "illustrated parts lookup tool", searching for "Horse." It helps to have the serial number which is stamped on the top, right of the main unit's transmission housing.
Most likely, you'll need the worm wheel, and maybe the worm gear with it's associated shaft, along with all the gaskets and oil seals shown on the diagram. I kind of hope you won't need the shaft with the worm gear, however, as I bet that's a pretty expensive part.
Good luck!
Great! Thanks, thats exactly what I needed. I will pull apart this weekend and order what I need.
The brass gear was so shredded I had a tough time getting all the brass out of the casing. I replaced all items on the horizontal shaft and left the main drive shaft as it seemed to be OK. It is working great. Now I just have to remember to check the dipstick regularly as I have the feeling it ran low on gear lube. Got the strawberry rows looking a lot better!
2016 BOBCAT T870 SKID STEER (A62129)
2016 BOBCAT T870...
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
2025 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
2008 WABASH 53X102 T/A REFRIGERATED TRAILER (A59909)
2008 WABASH 53X102...
karcher pressure washer (A61567)
karcher pressure...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
