My Trip to Power Trac
   / My Trip to Power Trac #11
Good luck with your new machine! Sounds like you had a great trip.
Well, I put an hour on the machine this morning, unloading attachments, driving around and getting a general feel for the PT experience.
Although the tractor is articulated, it is quite a different feel than the Ventrac that I had. I think the main reason for this is that on the PT, your seat is attached to the front frame whereas on the Ventrac you are attached to the rear.
The sensation is the same that I remember when I first drove a Ventrac, I felt VERY wierd... After a few hours with the PT, I know that feeleing will pass as my brain gets used to the difference.
It was a wierd feeling when I backed the tractor off the trailer!
One thing that I noticed right away that I don't like is the suitcase type of key that they used on the ignition? One thing I will be doing soon is taking that out and replacing it with an ATV type of ignition where the key housing covers the ignition when it is inserted.
OVerall, 9.9 thumbs up so far!
   / My Trip to Power Trac #13
Thanks for the great photos of Tazwell. Nice to see a picture of Scott, after emailing and phoning him prior to my purchase.
So how did the sales tax thing work? I thought if you picked it up you had to pay Virginia sales tax, or fill out some obscure paperwork?
I agree that the ignition switch leaves something to be desired. Let us (at least me) know when you've switched the switch and what to, photos would be good.
Dunno if you have followed a thread I started in "customization", but last night I installed a Supertrap muffler onto my 422 and, even tho I only ran it for 5 minutes, it was a significant difference on noise. I'll get a photo today, and maybe by tomorrow figure out how to make the file small enough to post. Already worth the $90 to me. The "muffler" manufactured and installed by PT doesn't do very much "muffling" IMHO.
Phil
</font><font color="blue" class="small">(
)</font>
I will post something as soon as I find the right switch to put on. I want to check out the switch used by Polaris on their ATVs. It is the same type of multi-position switch and the AVT keys come with a rubber boot that covers the switch assembly when the key is inserted. This keeps the water out.
)</font>
THanks Phil. I would be interested in seeing that. The tractor is loud for sure. Right now, I am wearing ear plugs.
Jim!
Phil:
Do you notice any reduction in power with the new muffler?
   / My Trip to Power Trac #16
Nice picts!
You sure are going to have a blast with your machine :)
Be sure to post picts of your projects and things cause that camera of yours looks to take good pictures.
   / My Trip to Power Trac #18
The ignition is a standard unit made for most tractors. I went to Sears and bought some additional keys that are larger and have a plastic knob that is easier to grab. Never have had any problem with water getting into the ignition.
PJ
   / My Trip to Power Trac #19
I got a little water in the hour meter early on. I eventually put it in a dessicant chamber at 1/2 atmosphere and left it there for a few hours. You should probably not hose off the instrument panel anyway.
   / My Trip to Power Trac #20
I didn't notice any drop in power with the Supertrap muffler. You size the muffler by HP..... 1 plate for each 3 HP. So my 22hp would take 7 and 1/3 plate... they come in packs of 3, so I have 9 plates installed which should be more than enough for 22hp. Under 6 plates and I'm thinking the backpressure would restrict HP on this engine. Plates are easy and quick to change, and I may try 7 plates and see if it reduces the noise any more without affecting power.
The muffler clamps on with a hose clamp. I tried that, but after a half-hour of stump grinding it fell off. It was VERY obvious when that happened, as it was instantly MUCH louder. I reattached it with a couple of screws, and will weld it on when I find the time and ambition. Got a big bonfire scheduled for today with much company (a birthday bonfire for a family member's big EIGHTEEN) so I may not get it welded for a few weeks. But it works fine held on with screws, albeit slightly loose.
This PT sure will come in handy today carting the dutch ovens up to the fire site! The hard part will be keeping everyone from driving it.... these are a little tricky for an unexperienced operator, what with no brake and all.
Phil
Utility Trailer (A52377)
Utility Trailer...
2017 John Deere 1025R Tractor - 626 Engine Hours (A57024)
2017 John Deere...
LOOK! (A53485)
LOOK! (A53485)
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
