My tractor won't start and I could really use some help asap
   / My tractor won't start and I could really use some help asap #1
vanguard
Raleigh, NC
2014 Kioti DK45SE
Over the last week or two sometimes when I turn the key my DK45SE makes a very slight click but doesn't engage the starter. It's the same symptom I'd have if I tried to start it with the PTO on or the tractor not in neutral. Normally I fiddle with the shifters and try a few more times until it fires up. I can't tell you if it was the extra turns of the key or the fiddling with the shifters but it would eventually start after a few tries.
Today it won't start at all.
I made a short video that shows the problem:
It's under warranty but if it's a simple fix I'd love to just handle it. The darn thing just happens to have a 1,000 lbs counter weight on the back so I'd like to avoid trying to get it to the dealer somehow.
Edit: This is solved now.
   / My tractor won't start and I could really use some help asap #2
It sounds like one of the safety switches has been acting up and finally bit the dust. Make sure the tractor is in neutral then try jumping across the starter with a screw driver and see if it starts. Warning this is not a osha recommend practice, and all the liability is on you if you try it.
   / My tractor won't start and I could really use some help asap #4
Bump to top
Well, I fixed it. It was the relay that I put my finger on in the video.
I've actually spent a fair amount of time turning wrenches on cars but something about it being a tractor and being a diesel made me doubt my normal trouble shooting process. Anyway, after this thread I got back out there and thought, "Well, power gets to the relay so this might be a good place to start."
$10 at autozone and the problem is solved.
   / My tractor won't start and I could really use some help asap #7
I am a day late and a dollar short:D
Glad you got it going..
   / My tractor won't start and I could really use some help asap #8
The starting price has been raised. Now you need and extra quarter in the coin slot. I REALLY like the video presentation format for a diagnostic question. It sure eliminates all the issues(s) about what the symptoms are due to...
Nice delivery !
   / My tractor won't start and I could really use some help asap #9
So - I didn't think in this day and time you could start a tractor , lawn mower , car, with out setting in the seat and your foot on the clutch . In the vid. your helper is not setting in the seat . Are you shure that's not the case ?
   / My tractor won't start and I could really use some help asap #10
On the DK series. As long as the range shifter is in neutral she will start. No seat switch, and there is no clutch on the tractor.
2010 Ford F-450 16ft Box Truck (A55852)
2010 Ford F-450...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2018 Ford F-250...
150 GALLON POLY SPRAYER (A57192)
150 GALLON POLY...
1957 (A57192)
1957 (A57192)
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A57193)
UNUSED JCT 84" HYD...
1999 CHEVROLET C7500 UTILITY TRUCK (A57880)
1999 CHEVROLET...
