My tractor got wet.
   / My tractor got wet.
You might want to consider changing the oil in your front axle and lubing any grease zerks/lub points that were submerged.
Good idea and probably time for that anyway. If I recall from the last time I did it a good while back, it is hard to get all the oil out of the axle (Kubota L4400). You have to raise the tractor up with the loader and tilt the axle to one side. Can't remember if there are drain plugs on both sides. (I left the owner's manual and factory service manual down at the cabin.)
In fact, it is probably time to change everything except the tranny/hydraulic fluid. Might as well do it all at once. I've got an extra fuel filter already too.
They burned a few of them down on Duck Dynasty :laughing: . Maybe you can smoke one out and then shoot it.
They had a lodge a few years back but do not have one now. Not sure where they sleep now.
   / My tractor got wet. #13
They do a lot of damage at my place. I had a local trapper who kept them pretty much under control but he committed suicide a couple years ago and the beaver have gone crazy. We spot them now and then but they really do their damage at night so trapping works better than shooting. Back in the old days dynamite did the trick. The game wardens actually did the blasting.
   / My tractor got wet. #14
Set some wire snares on the runways on the bank where they are coming out of the water to cut wood. Snares work better than traps in my experience.
   / My tractor got wet. #15
Could you build some sort of grapple hook to toss onto the dam and pull it apart bit by bit.
   / My tractor got wet. #16
The beavers at my place left on their own... after they cut down all the trees and got hungry, that is.
I spent a whole summer manually lowering their dam every afternoon (to keep the water from flowing onto the road), only to have them restore it over night! The conservation folks put a big plastic pipe through the dam, but the beavers just plugged it up. Ya gotta admire their work ethic. Imagine how productive the world could be if everybody approached their work that way.
BOB
   / My tractor got wet. #17
Tear out a section manually on an afternoon. Get to your blind and wait for them to start the repair work. A 22LR or 17 HMR with a scope mounted light will solve your problem. You might have to spend a couple of nights on the problem but this method is nearly a sure thing.
The same goes for traps - set your traps then tear out a section of dam near your traps. Snares or jaw traps will do the job.
+1 on the lube change and re greasing the front end on your tractor
   / My tractor got wet. #18
I live near a large lake. There is a local trapper that takes care of removing beavers.. He sets his traps and then he has a couple grapples that he made from rebar that he attaches to a static rope that he throws over the dams and then ties the ropes to his jeep and pulls the dams apart. He says that ripping the dams apart stirs the beavers into greater activity and then the traps are more likely to catch them
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
12 X 20 CAR PORT (A58216)
12 X 20 CAR PORT...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
