My Tires are no longer round ? ? ?
   / My Tires are no longer round ? ? ? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
I have a Gravely Promaster 260Z Zero Turn Mower. It has about 250 hrs on it. Its 4 or 5 years old. My front tires are Titan Super Guide 4 ply. One of the tires went flat after I ran it through a deep rut. The tire was leaking at the bead, so I inflated to 30psi (the max rating) and it resealed itself. While I was at it, I filled the other tire to 30 psi also. The next day I walked past the mower and immediatley saw that both tires are mis-shapen, bulged, and dented on the sides. Too messed up to operate the mower without bouncing up and down. I jacked up the mower and let all the air out and let the tires sit for 5 days. I then filled them to 20psi, and they are right back to being mishaped. I drove around a bit and it did'nt improve. What happened to my tires ? ?
(rims are not bent and do not exhibit any noticeable run-out)
   / My Tires are no longer round ? ? ? #2
Jerry, some of those little tires don't have the cords in them that most tires have, so you can blow them up like a balloon, but as you found out, that weakens the spots that stretched. You might be able to put lots of a stop leak like Slime in them and with low enough pressure get them to stay the right shape, but it's my guess that you're about to get a couple of new tires.
   / My Tires are no longer round ? ? ? #3
Keep an eye on them. The last time I had a set of tires that did that, they soon came apart. The cord separated inside the tire. I put on 6 ply after that and had no more problems.
   / My Tires are no longer round ? ? ? #4
I'm 99.9 percent sure that you need new tires. The old ones have been permanently strstched beyond their limit.
Looks like the predictions were correct. I wrestled one of the tires off the rim and found that all the plys were unraveled inside. The tires look like they have a wad of spaghetti in them.
New tires are on the way !
UNUSED Life Proof SPC Luxury Flooring (A50860)
UNUSED Life Proof...
UNUSED Brown Metal Roof Panels (A50860)
UNUSED Brown Metal...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A48081)
2009 Hino 268...
2012 Ford Edge SUV (A48082)
2012 Ford Edge SUV...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
