My TC - 29 sparked and then went dark....no start ??
   / My TC - 29 sparked and then went dark....no start ?? #11
I'd look at the ignition switch at this point. I suspect it is fried.
   / My TC - 29 sparked and then went dark....no start ?? #13
You get out your multimeter and you read the voltage at the ignition switch. Then read the voltage on the wire that feeds the starter solenoid. Of course voltage is not amperage so ok voltage may not indicate enough current to make work happen. Usually voltage will drop a lot with bad connections. No idiot lights suggests the positive feed to ignition switch might be bad. Still could be a bad ignition switch but you know nothing without getting a reading from the supply wire.
You need to figure out what failed and why. Here is a 101 course with some slightly higher follow up courses. Automotive Electrical 101 – Part 1 | Auto Repair Facts
Thanks much Jim RB....I am beginning the course , I have started reading, it is making my head hurt but I will get through this and figure this out or I will never be able to cut my grass again...my other tractor is trapped...Thanks again..
   / My TC - 29 sparked and then went dark....no start ?? #15
This troubleshooting page is from an older ('03) model but it may help with the ignition switch.
Sorry for the upside down orientation can't seem to get my PDF converter to save it right. :(
  • Ignition switch.pdf
Thanks Larry, I printed the page so I can take it to the tractor with me...will help a lot...
OK - Here is my update....I got it started & moved out of the garage so I could get my lawn tractor out and mow the lawn....but....still won't start...I have something going on with or around the battery...See if you guys can figure this out...I checked all the things mention by everyone in this thread,,thanks and it all checked OK...so...
As a last ditch attempt this AM I put my charger on the battery on the quick start setting and the tractor dash lights lit up and it started on the 2nd try...the first try it popped on the positive battery cable and did not start on the 2nd try it popped a little but started...When I finished mowing with my little tractor ...I tried to start the TC -29..the dash lights came on and I turned the key....and it clicked a few times like it is low on voltage...??? Even though the battery is one year old ( Auto Zone ) if that...and reads 12.5v...could the battery be bad ? could it be a cable >? And what about the spark at the positive terminal and the charger alligator clip. ?
Any thoughts appreciated
   / My TC - 29 sparked and then went dark....no start ?? #19
Bad ground wire. Check your main ground and start from there.
Murph....I know nothing about this electrical stuff...but do you think it could also be a bad battery I got from Auto Zone....it can't be more than a yr. old and I am having a hard time understanding how it can be anything but a bad battery if the tractor would not start with just the battery but when I connected the charger set on Quick Start ..it started....granted it still sparked and crackled at the positive terminal but it did start...Then when I tried to start it after an hour or so without the charger...all the dash lights came on and it just clicked when I turned the key then all went dark....It is sitting outside right now and if I went out and put the charger back on quick start it would fire right up...I don't want to put it back inside until I fix it since it blocks all the rest of our tractors...?????:confused3:
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
