My Slush Pusher - driveway saver
   / My Slush Pusher - driveway saver #11
I offer up what I've done, and can report each worked well on my BX2200.
Last year, not wanting to scuff the concrete driveways when moving snow, I bolted a 4 ft long 2x12 pine under the bucket, so the front of the 2x12 just extended beyond the lip of the cutting edge. I could go forward and load the bucket, or back drag with the bucket uncurled to vertical.
That 2x12 worked well, but this season, I hooked a chunk of driveway when lifting and broke the board in half. Wanting some denser wood, my neighbor with the sawmill brought me a 2x10 of white oak. It weighed twice what the pine board weighed! See pic 1.
This worked great for moving the first snow we had. The bucket filled and dumped fine, and didn't scuff the concrete. (I'd countersunk the 3/8" bolts into the oak so the heads didn't protrude.) However, the next storm gave us about 3" of sleet, which overnite promptly froze into one solid mass of ice. I had to take the oak board off as it couldn't penetrate the ice. Used the FEL cutting edge on about 12 driveways, and IMMEDIATELY noticed with the attack angle needed to break through the ice, I was rapidly wearing off the cutting edge!
I cut a piece of 3/8 x 5 strap and bolted it to the front of the cutting edge, so it extended about 2" beyond the Bota cutting edge. I didn't mill or sharpen the edge, just started in on the iced concrete again. After another dozen or so driveway cleanings, pic 2 is how the new cutting edge looks now. I have several options left: I can grind a better edge on the top side, or flip it over and let the concrete do the grinding. I could hard surface or heat treat the edge to protect it, but I have more of the material, so could just use this until I need to replace it.
I have not yet cut off the bolt heads under the blade, but plan to do that and flush weld the 1/2" bolts on the bottom, to eliminate that scuff potential.
The original cutting edge is H A R D, so when you try to drill through it, expect a fight! I had drilled those holes last year to mount a 6ft homemade lighweight "dozer blade" to the FEL. It looks a little like the slush pusher in Post 1 here.
I can report each works well. If we have snow only, the 2x10 goes back on. If it's ice, the board comes off exposing my sacrifical cutting edge. I plan on leaving this edge on, since I do a lot of work moving top soil that's been dumped on concrete. I just wish I would have thought of this 3 yrs ago when the tractor was NEW.
The next project I discovered while looking at the bottom of the bucket. If you look at the bucket edge plates, you will see (at least on mine) that they extend below the bottom of the bucket about 1/4". Mine, having ground on the concrete, are almost flush. My next welding project is to take some 1/4 x 3 or so strap, and weld three pieces as wear plates under the bucket. One at each end and one in the middle, extending from the rear of the cutting edge to the back of the bucket. These would be sacrifical also, but I think it will extend the lift of my bucket.
Hope this info helps.
Ron
   / My Slush Pusher - driveway saver #12
Pretty cool, Ron. We have asphalt and not concrete, but I also noticed VERY signficiant wear of my cutting edge. I'll suffer through this winter and limp along until I cut out and replace the stock cutting edge (or replace the bucket), but I very much wanted to mount a 'wear plate' to help diminish the damage to my bucket when doing the neighbors a favor.
I liked the 'slush pusher', but A) I don't have enough time to devote to building something that pretty and B) We normally get snow followed by sleet and I use the "bucket" part as much as the "pushing" part when moving heavy snow. In other words, I'm not sure a big squeegee would help me.
Need to do something, though. Really killed my cutting edge this time around on an aggregate of probably 2,000 lf of driveway as well as the areas near 7 garages.
   / My Slush Pusher - driveway saver #13
Ron,
I love my snow "Pusher". Second season. It's far enough ahead of the FEL that I can push snow piles over culverts and ledges without falling over. Teamed with a Woods six foot BB (W/Gauge Wheels) it's a great combo. After two seasons, I haven't needed to change the bottom cutting 2X8. Four bolts and the FEL is freed up.
I like your design with the rubber.
BD
   / My Slush Pusher - driveway saver #14
bigdad said:
Ron,
BD
I remember seeing this earlier and thought it was a great Idea myself
   / My Slush Pusher - driveway saver #15
BD:
Does that rig get you down to the bottom of the snow? Or does it skate on top a bit? That looks simple enough to build that maybe I could give it a try for myself.
To be honest, no matter how beat to heck it gets, I'm still a little uncomfortable making holes in my bucket. Not like I can't do it or am worried about it, I just know when I start that I won't stop and I'll have swiss cheese in 3 years. Perhaps I'll try and secure it with clamps or something.
   / My Slush Pusher - driveway saver #16
KeithInSpace said:
BD:
To be honest, no matter how beat to **** it gets, I'm still a little uncomfortable making holes in my bucket. Not like I can't do it or am worried about it, I just know when I start that I won't stop and I'll have swiss cheese in 3 years. Perhaps I'll try and secure it with clamps or something.
If you can weld you can have a piece of stock slip under the bucket and a matching piece slip into the bucket. Drill a hole in the top piece that goes in the bucket. Weld a nut on the top and thread a bolt through the nut and through the hole and you have a friction bite on your loader and no extra holes
   / My Slush Pusher - driveway saver #17
Yup, Timber, something like that. Then if you put angle on the bottom instead of raw wood, it would last next to forever. Mount that whole rig low on the bucket so the bucket rides an inch or so above the asphalt. Then put some braces to the top of the bucket so the moment at the bottom doesn't fold the whole thing backward under the weight of the snow. Loosen a few bolts and slip it off.
If you want to go really crazy, put an HDPE or rubber wear strip under that piece of stock shielding your wood.
I did notice some minor scrapes on my asphalt, but that may be the sharp edge and my angle of attack. With this thing like BD's, you have more of an angled plow without paying all the money for a plow. Don't really need to change the angle, I don't think.
Gauge wheels on the box blade. Hot. Combine that with the lift chains (in place of the lift bars) I saw in another thread and it would conform perfectly to whatever you're doing...even better than a rear plow, maybe. Pretty good ideas flying around.
it would be pretty easy to mount a pair of skid shoes too...that would save the bottom edge. I suspect I may be adding shoes to my pusher for next season.
   / My Slush Pusher - driveway saver #19
Hi guys..... Bigdad again. Sorry if I mislead you on the gauge wheels. They are on a B-ack B-Blade.... not a boxblade. Also, I considered putting a metal blade or angle iron on the bottom of the board(s) but didn't want to scrape up blacktop. It seems to get down to the bare pavement if it isn't too packed anyway. (Then I use the Woods) I forgot to put in the first post that I always float the FEL when I'm pushing. If nothing else, it lets me know when the blade falls off of a ledge and to STOP! Ha!
This set up was really CHEAP and actually works better than I hoped.
BTW...thanks Timber. I always watch your posts.
BD
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
PALLET OF RTV SILICONE (A51244)
PALLET OF RTV...
2007 Polaris Ranger (A50514)
2007 Polaris...
2015 Toro Z Master Professional 64in Zero Turn Mower (A50322)
2015 Toro Z Master...
2015 Silverado 1500 (A50323)
2015 Silverado...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 72"...
