My set-up
   / My set-up #11
This is right at 21,000#. The pickup is equipped with an exhaust brake and the trailer has Dexter axles with electric brakes. My brake controller is a MaxBrake with a parking brake feature I use for loading and unloading. I’ve never had a runaway with a parked trailer because I block the wheels when unhitched. This type setup works great for us in the United States. I’m sure you can find lots of YouTube videos that show trailer disasters - mostly the “hold my beer” mentality. A little common sense and good maintenance, combined with good driving habits, makes for a good trailering experience.
If you use the search feature, you’ll find the differences between American and European trailers, trucks, etc., have been cussed and discussed to no end…
   / My set-up #12
I've often wondered the same as the OP's question. I hate electric brakes and they certainly need almost an oil change like interval to keep them working.
   / My set-up #13
Most electric brake problems can be traced to improper wiring practices, mostly done at the factory. A properly wired trailer, combined with a quality brake controller and properly wired tow vehicle, will provide a happy towing experience. In 50+ years of towing trailers with electric brakes, I’ve found most brake problems to be self inflicted. :)
   / My set-up #14
I rewired my trailer several years ago. Replaced the factory wiring, installed backing plates and new huns, and installed electric brakes.
The only issue I have had with it was a mud dobber decided the plug made a good spot for a nest.
After cleaning it out, everything has worked flawlessly.
Original wiring was installed guitar string tight and I started developing shorts in the wiring from rubbing on the frame.
   / My set-up #15
Often times the brake wiring may be correct but use the "Scotch Lock connectors." Connectors and butt connectors (heat and solder) have changed a lot in the last few years and can be waterproof and durable. That reason alone is enough to merit rewiring.
   / My set-up #16
ive rewired all my rigs and i have never had any issues with electric brakes......on rental trailers with surge brakes, im less than enthused. i can feather breaking ability depending on the load with electric brakes.
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X115619 (A57453)
2009 Ford Crown...
METAL SHELVING & COOLERS (A58374)
METAL SHELVING &...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
flatbed trailer 24ft (A56857)
flatbed trailer...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
