My RX7320 is home.
   / My RX7320 is home. #1
WoodChuckDad
Elite Member
Free Union, VA
Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
The RX7320 was delivered this morning. I drove it onto the property and parked it. I had to wait about 5 hours before I could do anything with it because I had other work to do and had to go out in the woods to check up on the forester to see where he marked for cutting.
When I finally got a chance to get back into it, I didn't really have anything to do...Nothing has been cleared yet, so I drove to the front of the property where there is a little turn around with a debris pile about 3/4 of the way across it. I pushed that into the woods and cleaned up a couple fallen logs...just pushing them with the loader. Then I drove it back down to the pond and decided I didn't like where it is sitting. I want to have a covered area off the main driveway to store it ....I had figured I would rip out the mountain laurel with the grapple but I don't have that yet....so...I got some practice using the FEL and the box blade. I am very impressed. Figuring out how to use the FEL will take a bit of time but I was happy with the results. About 30 minutes of work produced a space in the woods big enough to park the Tractor. I'm going to expand it just a bit and drop a few 16 foot 4x4 posts in the ground and throw up a quick pole barn style cover to keep it out of the elements and out of the tree sap. One thing I discovered...you have to be careful putting down the loader as you dig forward because it is easy to raise it up on 2 wheels....and it still keeps going forward. It was very cool to look at the woods and think that I would like to be able to park there but couldn't because there were small trees in the way.....and then just push them the heck out of the way so I can park there.
One small issue. after I parked the tractor I looked down and saw a nut on the ground. Can't figure what it came off of. Looked all over the tractor but can't find it. I am sure it will make itself obvious at the worst time. Gonna get down underneath the tractor this weekend and look.
Edit--I forgot the best part. When I came home tonight, The wife was wearing a Kioti tractor t-shirt she ordered to celebrate this momentous occasion.
   / My RX7320 is home. #2
Great looking tractor,enjoy..
   / My RX7320 is home. #3
Congrats, looks awesome! Keep the pictures coming.
   / My RX7320 is home. #5
[snip]
[snip]
Nice update! You'll get a lot done with that tractor!
The loose nut looks like it fits a 14 mm socket. There is a nut like that at the very bottom of the FEL bucket-level-indicator rod. It does not thread onto the rod very far. Check to make sure it's still there before you operate the tractor again. There have been a few instances in the past where it's come loose on other Kioti models, with damage to the rod before it was noticed. In fact, it's a good idea to loosen and resecure it with blue threadlocker now, even if that isn't the one you found.
Thanks, Threepoint. , I will check that out this weekend.
   / My RX7320 is home. #8
Nice tractor! I would check the loader subframe and wheels for the missing nut. You need to put a wrench on them all anyways.
I did a quick check of the loader. But will be more thorough Saturday. Too small for the wheels.
   / My RX7320 is home. #10
Congratulations on the tractor! The RX7320 is my favorite Kioti tractor... drool... I was going to say the same thing about the nut, to check the bucket level rod assembly. I had one come loose from there also.
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
LEEBOY 8520 ASPHALT PAVER (A51242)
LEEBOY 8520...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
